Page 2 of 2
Re: NERTIA POWER BOOSTER SET YUMINASHI
Posted: Sun Mar 16, 2014 1:56 am
mikelx5 wrote:not really its a wieght thats almost the size of the flywheel
Weight. My PCX doesn't have a flywheel...
Posted: Sun Mar 16, 2014 3:38 am
by mikelx5
yes it does its right behind the radiator the fan bolts to it.
also found out the fan has to be modified to not touch the radiator mine was and bent some of the fins
Posted: Sun Mar 16, 2014 3:41 am
by mikelx5
i know hitari you dont like modders but no reason to slam somebody willing to try something new that hasnt been tested much
Posted: Sun Mar 16, 2014 6:50 am
mikelx5 wrote:yes it does its right behind the radiator the fan bolts to it.
Does it? Never knew that.
Posted: Sun Mar 16, 2014 6:53 am
mikelx5 wrote:i know hitari you dont like modders but no reason to slam somebody willing to try something new that hasnt been tested much
I've modified my bike and I'm sure I wasn't slamming anybody. Whatever that means
Was just pointing out its more of a washer, that possibly adds some "flywheel" weight rather than a booster of power
You are entitled to disagree. And slam away if you want
Posted: Sun Mar 16, 2014 6:39 pm
by mikelx5
slamming is putting the person down. you are correct on adding weight i was just stating the fact its quite a bit larger than just a washer. and i thought about it now that im sober it wasnt so much a slam but always being against modders isnt needed on the "performance" section. you you i wasnt saying anything about you i was just explaining in better detail
Posted: Mon Mar 17, 2014 2:51 pm
mikelx5 wrote:slamming is putting the person down. you are correct on adding weight i was just stating the fact its quite a bit larger than just a washer. and i thought about it now that im sober it wasnt so much a slam but always being against modders isnt needed on the "performance" section. you you i wasnt saying anything about you i was just explaining in better detail
What size is it?
Posted: Mon Mar 17, 2014 3:38 pm
by mikelx5
its between 5 and 5 1/2 inches diameter and about 1/2in tall
