Engine stalled
Re: Engine stalled
Don't they make platinum plugs like cars have? Cars now can go 100,000 miles on the same plug.
logepoge1
Re: Engine stalled
Post by logepoge1 »
maddiedog wrote:http://www.amazon.com/dp/B00311ANNO
6 in stock ;)
I am beyond irritated right now. I broken the new spark plug
And fouled the old one now. Now the old one, I could still ride the bike, but there are noticeable misfires
OriginalRocket
Re: Engine stalled
Post by OriginalRocket »
Relax, breathe, relax. spark plugs are... cheap... be happy you broke the top half and not stripped the soft aluminum engine head.
It is a tight fit to get at the plug opening, but if you go slow, relax, it will work.
Good luck on your next spark plug install adventure.
logepoge1
Re: Engine stalled
Post by logepoge1 »
OriginalRocket wrote:Relax, breathe, relax. spark plugs are... cheap... be happy you broke the top half and not stripped the soft aluminum engine head.
I bought this one for $7 at the dealership. Since it was 6pm when I decided I needed to do this again but didnt want to throw away more money, I went to Advance Auto Parts(who originally said they were out of stock along with Autozone and Oreillys) and they ordered me one that I will pick up tomorrow for $3.03. Same exact plug(NGK CPR7EA-9) just doesnt have honda logo on it. Getting it tomorrow but scooter still technically runs more.
I think that the stalling problem is because of spark plug though. The old one was almost solid black charred. I put it back in and now it stalls way more but as long as I ease the throttle up I can still reach full throttle speeds. It stalled on me at stoplight and I just pushed electric start again. Simple. But I do want to replace it soon.
Re: Engine stalled
Is your air filter clean?
DAB
Re: Engine stalled
Post by DAB »
logepoge1 wrote: The old one was almost solid black charred.
Low MPG and black charred plug, fuel/air mixture ? Do you just do very short journeys where the engine does not reach operating temperature?.
Clean the plug and thrash it for 20 miles, try some fuel additive (injector cleaner), Redex in UK but not sure what is available in the states.
Good luck
Other rides
Re: Engine stalled
DAB wrote:Clean the plug and thrash it for 20 miles, try some fuel additive (injector cleaner), Redex in UK but not sure what is available in the states.
Seafoam is best in the USA.
logepoge1
Re: Engine stalled
Post by logepoge1 »
Got spark plug changed out. Talked to guy at advance auto parts who happened to be a motorcycle mechanic and he told me the right way to change it. I was accidentally over tightening but didn't damage anything thankfully.
nacho
Re: Engine stalled
Post by nacho »
My 3 year old PCX would almost stall at a light too. I replaced the battery and works just fine now, or it did until Wednesday... I think I blew the engine.
logepoge1
Re: Engine stalled
Post by logepoge1 »
Ouch. I don't have the problem anymore after replacing the spark plug. I think some bad gas might have been the issue since I didn't have problems until the day after I filled it up from a different gas company. I normally use Exxon and whatever Walmart uses, throw In a circle k too, but I had trouble after filling at a shell station
