Question regarding smartkey system
Re: Question regarding smartkey system
op3l wrote:
Gil wrote:Maybe you are leaving the key close to the scooter and that might be activating it? Wrap the key fob in aluminum, so that it wont connect, maybe?
That's impossible. I live in an apartment complex on the 8th floor. There's 8 floors worth of concrete and steel between key fob and bike and no direct view of the bike.
It is possible I turned the alarm on and that slowly drained the battery over the course of now that I think of it almost a month. I'll make sure to turn the system off next time I leave it sitting and will update back to see if it's all normal.
If it was a month then any “battery” will be marginal at that point.
op3l
Post by op3l »
My other scooter is a carburetor scooter and that had no problems with the battery. So i guess the new fuel injected scooters have some system that uses electricity huh?
General rule of thumb for lead acid accumulators is that they naturally lose 1% of charge per day and need around 70% to start a vehicle. Therefore after a month they are on the limit.
pcx888
Color: pearl white
Post by pcx888 »
you you wrote:
op3l wrote:
you you wrote: thats why I switch to lipo battery. Never failed me yet.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
