Hi
Re: Hi
Superman is good at building ANYTHING... just waiting on superman :)
chicaboo
Re: Hi
Post by chicaboo »
But can he replace the highbeam rocker switch without removing the whole assembly?
That's the answer America is dying to know. Juan thinks it's safer just to remove it.
Re: Hi
chicaboo wrote:But can he replace the highbeam rocker switch without removing the whole assembly?
I will pass on this mod and just toggle the existing switch if flashing in needed.... Juan
d.a.rous
Year: 2014 JF57(125)
Color: Carbonium Grey
Re: Hi
Post by d.a.rous »
homie wrote: 1. Is the toggle action spring loaded or click lock?
2. Auto Flashing or manual?
3. Can switch be pulled out, removed and rewired without opening the control unit?
1. spring loaded
2. Manual
3. Unfortunately not, in the control unit the cables are fastened inside with a clip, so the cables fall out shorter around the switch. To disassemble the control unit is uncomplicated.
Sorry my English, translate through Google.
Couple videos how that works
https://vk.com/topic-27452469_34148283? ... 2da9b88bcc
https://vk.com/video340017306_456239018 ... 355f8ffc39
YSS G-Euro XL Red shock
Dr Pulley SR2015 13g sliders
Dr.Pulley SP2015-AK sliding pieces
SH Clutch (Facilitated)
Malossi Clutch Spring (Red)
High beam Passing (Flash)
Low beam switch (on/off)
Oxford HG "Touring"
Drive Belt Cover + Swingarm (Matt Black)
Michelin City Grip
Re: Hi
Ok.. that is pretty cool now that I see how it can be operated so fast.
d.a.rous
Re: Hi
Post by d.a.rous »
In the picture no. 5 is this clip, which must be made loose.
And have still made a picture with connection differences between SH and Pcx models + modification.
PCX Passing Mod.jpg (48.66 KiB) Viewed 963 times
Oxford HG "Touring"
Michelin City Grip
