need help
need help
Good Day Guys! i need your help, i seldom use my pcx, it was just park at our garage for few months. when i started using my bike again , i dont whats wrong with it. the fuel gauge suddenly blinks. eventhough the tank is filled-up. I need some advice on this matter, anyone who can spare knowledge on this. i'll be very greatful. Thanks in advance
				Cooley_PCX_Rider
Re: need help
How many miles on it?
Is the fuel fresh?
Does it run well?
									Is the fuel fresh?
Does it run well?
PCX 150 Rider from East Central Illinois in the middle of the United States of America
Re: need help
Did you winterize the bike before storing it for a few months? If not, it's possible the stagnant fuel has damaged the fuel system or gummed it up. At the very least, you should siphon the gas out of the tank and put fresh gas in.
Is the bike even starting? Just for a sanity check -- when you start the bike, is the kill switch set to on? The kill switch is on the right side, next to the throttle... In addition, make sure the kickstand is up and the left brake lever is fully depressed before trying to start it.
Even if the fuel sensor indicates the tank is empty, it should still start.
Currently ride:  Nothing right now - mostly mountain biking with my boys until they're old enough to ride
Re: need help
If it helps, the only time I have seen the full fuel gauge blink, is when checking the valve clearances. Had the fuel pump disconnected and turned it over.
If its not starting I would guess a problem with the pump.
