Homie's Garage
Re: Homie's Garage
It's true youyou I went in for lifters as these are about due and realized if you are going in do it all. Might as well learn something since these parts are not too awful expensive. It's the labor that would have been over the top for all this extra work. I will check discarded parts for service tolerances and if they are still usable... save or sell them so nothing goes to waste
Re: Homie's Garage
Held up for stainless header fasteners, waiting on these 4 nuts is too much time to second guess the work
Should sound like it did off the factory line, if not I'll do it over... that's my warranty
Re: Homie's Garage
Primed the engine oil circulation by removing the spark plugs & fuel pump fuse then turning it over with short bursts of the starter. Using 10w40 conventional (petroleum base) non-synthetic oil for the initial heat cycling.
Ran my diagnostic program... no errors codes
all systems checked out and passed! Took a deep breath and hit the ignition. FIRED UP and brother that sounded so good.
Run for a few seconds, kill switch and cool down. Start again run for 1 minute, cool down. 1.5 min then 2 min's, total run-cool cycles and now its time break in those new parts
20 miles of moderate acceleration & equal deceleration in 36 degree weather to get the rings seated in a full 360 degrees. Then I'll dump and replace with more conventional oil riding a little more aggressively. Don't know how many miles I can get on the break in before I freeze but hopefully enough until spring.
- relic
- Color: red white
Re: Homie's Garage
You must be feeling good=accomplishment.
Give yourself a pat on the shoulder.
Always good to hear when these projects are successful.
Running your throttle up and down as I understand is a good way of seating the rings.
Re: Homie's Garage
Great work Homie! I only have a front yard which has bad tarmac (rough, holds water, etc) so loath to do any stripping of my PCX, but even if I had a garage like yours I doubt I would be able to do what you do - scary stuff
Re: Homie's Garage
Ok I'm a believer in mototune's break-in theory
The next time I buy a new vehicle with zero miles I'm dumping whatever synthetic it shipped with and running it hard with cheap oil for 1500 miles. No more owners manual recommendations that serve only to poorly set your rings and allow pollutants to pass the piston into the crankcase for the rest of that vehicles engine life
There is a better way... who knew? Well this guy apparently.
http://www.mototuneusa.com/break_in_secrets.htm
I will test the rear cylinder but the compression testing now and again at 1500 miles is proof enough for me. This engine is going to run stronger and harder than factory owners manuals would deliver on break-in. So why? why does the industry screw us on break-in? Is it just for convenience or something more cynical?
Re: Homie's Garage
And I'm going to bark at the moon...
- DailyRider
- Color: Dark blue
Re: Homie's Garage
[quote="homie"]
[/ quote]
Surely you've been warned about believing what you see/read on the Internet
[/ quote]
Re: Homie's Garage
There can't be many car or bike forums the old mototune chestnut hasn't been passed around. That and the oil one. Oil Bob or some such.DailyRider wrote:homie wrote: Ok I'm a believer in mototune's break-in theoryThe next time I buy a new vehicle with zero miles I'm dumping whatever synthetic it shipped with and running it hard with cheap oil for 1500 miles. No more owners manual recommendations that serve only to poorly set your rings and allow pollutants to pass the piston into the crankcase for the rest of that vehicles engine life
[/ quote]
Unprovable opinioscience but if it floats your boat....., just don't spread it as fact.
- DailyRider
- Color: Dark blue
Re: Homie's Garage
Yeah,
it belatedly occurred to me that Homie was probably kidding.
Re: Homie's Garage
I guess to really follow up on the results of mototune's claims (if 12.5% increase in compression over factory wasn't enough for you) I'll have to pull these pistons at 10k and check for scorching under the rings and scuffed skirts from improper distribution of forces across the tops of my pistons. Now let me ask you people this, If they come out as clean and shiny as those shown with perfect skirts having ridden the cylinder walls evenly over time... would you be a believer then?
Hey all I'm saying is I took the guys logic and ran with it. A gutsy thing to do given all the opinions over break-in. It could have cost me time and money but instead I'm looking at 12.5 % increase in compression over SM specs. Time will tell us the truth, you know I will follow up
It's not speculation if the results are factual. I ran my bike in HARD willing to take the chance, you have to give me something for that youyou. Read it again, find me some bad logic in it and lets talk about it.
And look perfect timing... SNOWING!
- GeorgeSK
- Year: 13PCX,15Forza
- Color: Both Red
Re: Homie's Garage
Homie, I have absolute faith the you WILL take the sucker apart around 10K. Your report will belong at snopes.com, either confirming the technique (which I certainly hope will be true for you), or debunking it. Either way, I DO applaud your willingness to perform the real experiment with your own machine and labor.
Re: Homie's Garage
Thank you George and a Merry Christmas to you and yours. Still thinking about how the need to rev up our little Honda's just to operate the CVT might give us more of a mototune break-in than we think. There is no lugging or terribly low rpm with a scooter and pretty good engine braking as well. I don't think scooters can be nursed like clutch bikes can on break-in even if we tried. What do you think?GeorgeSK wrote:Homie, I have absolute faith the you WILL take the sucker apart around 10K. Your report will belong at snopes.com, either confirming the technique (which I certainly hope will be true for you), or debunking it. Either way, I DO applaud your willingness to perform the real experiment with your own machine and labor.
I've learned a lot with this project, but never enough. I did not know pistons and rings had such a story to tell about how we break in a new engine. I do have to consider all the other parts that might suffer from a hard break-in as it might not be just about compression and blow by to the crankcase and bearings for the life of the engine... but that's a very compelling argument worthy of choice.
