Rear wheel noise - URGENT!!
Re: Rear wheel noise - URGENT!!
That tells me that Honda is still having that problem.
Holding a 2011-13 rear wheel bearing to measure and compare to the later model part to see what if any changes where made for LED 2015 PCX. Separate part numbers as of 2015 so maybe modifications where made, we shall see. After I have this information I will have no need for this one.
I do not believe my bearings are failing at this time but due to availability and back order of these I'm having one on hand just in case.
- bearing2.jpg (62.11 KiB) Viewed 3098 times
- Oyabun
- Year: `12,`15,`19
- Color: black&black
I was thinking about changing the bearings myself, but for roughly 30 USD it'd be cracy to even think about it. The 39mm nut holding the torque spring and driven pulley together was a bi@tch to take off, but otherwise it was a straightforward task.
Regular cleaning and regreasing will now be on my agenda for every oil change to avoid the bearings go prematurely.
Looks like you need an extra set of hands to reassemble, if you don't have a special tool.
- Oyabun
- Year: `12,`15,`19
As they say your feet are allways at hand. ;-)
The Thai special tool to use is to sit on a chair, put some cartboard on the floor to protect the parts, rewssemble everything and put even pressure on the parts with the feet to be eble to torque down.
Flip-flops are optional work safety items ;-)
LOL I was looking for that video but haven't located it yet.Oyabun wrote:As they say your feet are allways at hand. ;-)
- RichyP
i am so glad someone else has posted this as i have noticed my 2013 PCX rear wheel has started making the exact same noise!Decco-Pcx-125 wrote:This is a video of the noise related to this problem
https://m.youtube.com/watch?v=cqd4b1_ApZA
PCX 125 CANDY RED
- Color: RED
