Please continue where you left off, Sendler and Nobody, and next time, just ignore the flame bait please.
Without proper timed testing the only thing you will ever know about this increased rpm is that it means increased fuel usage.sendler2112 wrote:It now immediately down shifts, or revs up, whichever way you want to look at it, when increasing the throttle. All of the rpm ranges were shifted upwards. Even mild coast down. Light cruise at 30 mph is running 5,000 rpm now and it immediately jumps to 6,400 on accel.
So lets get this straight, you don't even know the properties of the product you have purchased so how can you possibly asses what it's supposed to do?sendler2112 wrote:Maybe this is the 1,500 rpm the rating is referring to.
sendler2112 wrote:may even spend some more money to see if there is any difference with a kevlar belt.
No such thing, it's a CVT.sendler2112 wrote:Kick down
I think he's referring to the pin and slot that varies the ratio progressively. Since the power band isn't linear, it makes sense for it to have the "kick down" to vary the gear ratio nonlinearly as well... It's just like where Sendler says "immediately downshifts" -- he's not suggesting it's actually shifting down a gear, he's implying the gear ratio is dropping. You can't be so literal, this isn't a technical document... It's documentation of experimentation.gn2 wrote:No such thing, it's a CVT.sendler2112 wrote:Kick down
The "rpm" ratings on contra springs are basically misleading. The only reason I can see for the 1000/1500/2000rpm etc ratings is to differentiate the increases in tension from a particular manufacturer. Either a xx% difference from stock or an actual rating (there is a company that does this-forget who) is really relevant. In my case the SP Takegawa is 11% uprate. RPM? no relation in my book.gn2 wrote:So lets get this straight, you don't even know the properties of the product you have purchased so how can you possibly asses what it's supposed to do?sendler2112 wrote:Maybe this is the 1,500 rpm the rating is referring to.
I think I understand the context but think the logic may be off a bit. Now with a higher contra spring rating the clutch can close much faster when you roll off the gas and rpm's drop, causing the cvt ratio to decrease. Now when you get out of that sharp corner going up Alp d'Huez and hit it, I could see why the term 'kick down' could be used. Engine revs pick up much straight away and the acceleration is there due to the lower ratio, like an auto transmission has kicked down a gear. With the stock settings you just feel bogged down.gn2 wrote:No such thing, it's a CVT.sendler2112 wrote:Kick down
We don't have to touch the variator ramps. Because the DR Pulley sliders don't ever roll, they have 4 specialized surfaces. Each one with a different job that is normally done by four lines across the surface of the round rollers. The bottom of the slider is roughly round to approximate the shape of the roller as it follows the ramp. The top of the slider is flat and angled to ride against the plate. The other two sides are the high and low stops and could be shaved to any thickness just shy of having the belt ride off of the pulley at the top or go slack at the bottom. The sliders are a brilliant design and become obvious when you consider that many "rollers" are always sliding on a flat spot anyway.maddiedog wrote:rather than modify the variator, would using a smaller set of spacers between the pulleys accomplish the same effect? It seems less costly if you accidentally screw up.
If you are not hitting redline with the standard rollers installed, it is obvious that the spring is much too strong. The good old GY6 must be using a higher tension (could imagine this as the PCX is current tech design to minimize losses). Before playing with belts I would try to get a spring fit for purpose. Dropping effective roller weight with sliders would only make this worse.sendler2112 wrote:.
But in just a day of riding I can see several down sides to a super stiff contra spring. There is an obvious increase in the running losses in the belt. I think the increased compression on the sides of the belt, and the increased tension, are creating added friction and heat losses. The loaded hill climb speeds are down a percent to 49 mph. Top speed is often way down to the 63 mph range. Some of this my be due to the tighter belt riding down lower in the front pulley but I am also sometimes not making it to redline, indicating some loss somewhere.
And of course, top speed.sendler2112 wrote:I have been methodically testing all of the changes I have made to my PCX150 with 0-50 times, weighted hill climb speeds, and fuel economy data.
