Sayonara Dr. Pulley
- ScooteringAbout
Re: Sayonara Dr. Pulley
Would it be possible to put 13G Rollers into my 7,500 stock variator? sorry if this is a stupid question.
aka DrewJW
- Year: 26 adv 160
I have 13g sliders in my stock variator, could not be happier with the mod.
- sendler2112
- Year: 2013 PCX150
Variators don't really have an rpm. The mass of the rollers controls what rpm they pull at. The stock rollers are really too heavy for the best acceleration.
- ScooteringAbout
Can you share where you got them from?Jge64 wrote:I have 13g sliders in my stock variator, could not be happier with the mod.
aka DrewJW
- Year: 26 adv 160
Don't remember but google "dr pulley pcx" and ill bet youll find them.
- flyingzonker
I took my PCX out for a long ride for the first time since I went back to stock rollers from Dr. Pulley.
I felt like my friend had come back to me after a long absence. Or, it was the kind of feeling you get when, after a long illness, you return to health. I, for one, will fool with the variator no more.
Zonky, can you confirm that you had SR2015 sliders, and not SR1814 or something off?
- flyingzonker
I'm afraid mine were 1814.chicaboo wrote:Zonky, can you confirm that you had SR2015 sliders, and not SR1814 or something off?
You need SR2015. The 1814s will cost you speed since they won't push out far enough on the variator plate.
They probably rattled around line a spray can, too? In future anything labeled as 20x15mm is safe to run.
- sendler2112
- Year: 2013 PCX150
Maybe you should change the title of the thread to "Wrong size sliders for the bike installed and I didn't like that they weren't working right". Instead of implying to everyone that installing the correct DrPulley sliders would be a step backwards.flyingzonker wrote:I'm afraid mine were 1814.
- Year: 26 adv 160
Thank you......sendler2112 wrote:Maybe you should change the title of the thread to "Wrong size sliders for the bike installed and I didn't like that they weren't working right". Instead of implying to everyone that installing the correct DrPulley sliders would be a step backwards.flyingzonker wrote:I'm afraid mine were 1814.
- ScooteringAbout
Jge64 wrote:Thank you......sendler2112 wrote:Maybe you should change the title of the thread to "Wrong size sliders for the bike installed and I didn't like that they weren't working right". Instead of implying to everyone that installing the correct DrPulley sliders would be a step backwards.flyingzonker wrote:I'm afraid mine were 1814.
Would these be genuine ones?
http://www.ebay.com/itm/Dr-Pulley-Rolle ... 1326893746
aka DrewJW
- Year: 26 adv 160
They are genuine. The knockoff designs are orange from what I've seen.
- flyingzonker
Well, the bike seemed louder to me with them in--but I thought it was engine noise. Maybe it was a fast rattling variator.chicaboo wrote:You need SR2015. The 1814s will cost you speed since they won't push out far enough on the variator plate.
With the sliders I hear a sort of scrubbing sound as I drop the revs when they aren't quite fully engaging the variator plate. But nothing awful...flyingzonker wrote:Well, the bike seemed louder to me with them in--but I thought it was engine noise. Maybe it was a fast4 rattling variator.chicaboo wrote:You need SR2015. The 1814s will cost you speed since they won't push out far enough on the variator plate.
Are you going to try the correct size and have another crack at it? If you do, you might be happy with 12g or 13g for your weight.
- Oyabun
- Year: `12,`15,`19
- Color: black&black
You're right, using lower variator weights means that the engine will run on higher revs - thus will be louder.flyingzonker wrote:Well, the bike seemed louder to me with them in--but I thought it was engine noise. Maybe it was a fast rattling variator.chicaboo wrote:You need SR2015. The 1814s will cost you speed since they won't push out far enough on the variator plate.
What I believe the other inmates meant that the smaller sliders can rattle - especially at idle when there is no tension on them.
