And if they're both black, you have a 50-50 chance of creating a puff of Magic Smoke!Mel46 wrote:Here is a way to always know which is hot and which is ground...if the wires are red and black...I used this in aircraft electrical school to remember.
Red is always "positively red hot".
A couple of really odd questions...
- Ishkabibble
Re: A couple of really odd questions...
That was a funny comment of gn2s. The puff wafting up, the smell, the remorse...
If they are both black someone screwed up! Could you imagine if every single wire in the PCX was black?! The only way to know whether you got the correct one was to watch for the smoke! Poof!! Poof!! Poof!! OK! Wow, that was easy!
- Ishkabibble
Both of the wires on the power supply were black.
Hence my comment.
This was a really interesting experience.
Thank you all
Hence my comment.
Thank you all
- honkerman
Try working on a Harley...lots and lots of black wires. It gets a bit crazy.Mel46 wrote:If they are both black someone screwed up! Could you imagine if every single wire in the PCX was black?! The only way to know whether you got the correct one was to watch for the smoke! Poof!! Poof!! Poof!! OK! Wow, that was easy!
- honkerman
If you're not sure, you can always use a multimeter set to VDC (Volts DC). touch one meter lead to one wire and the other to its opposite. If you get a positive reading, the one on the positive meter lead is hot and the one on the negative lead is cold. if you get a negative reading, it's the opposite. Simple.Ishkabibble wrote:Both of the wires on the power supply were black.
Hence my comment.
Thank you all
- honkerman
This gets a bit more complicated in a motorcycle harness...Unless it's a Harley, then, like I said before, most of the wires are black. Good times right there.Mel46 wrote:Here is a way to always know which is hot and which is ground...if the wires are red and black...I used this in aircraft electrical school to remember.
That's because they are massed masnufactured by machine and the polarity will always be correct when assembled - until someone chops the end offIshkabibble wrote:Both of the wires on the power supply were black. Hence my comment. This was a really interesting experience. Thank you all
Those small encapsulated supplies can last a long time if run under max load, but if you run them near max load for too long they tend to die suddenly due to heat and no ventilation (not a good idea to drill some unless you know what you are doing - so don't!)
If I were you and the tester I was going to use a lot had only black leads, I would get some red heat shrink and put it on the + lead so that you would know it from then on. I do this on a lot of things.
- GeorgeSK
- Year: 13PCX,15Forza
- Color: Both Red
Good for you, Ish - You can't win or loose if you don't make the bet.
As Iceman said, one side of the wire might have a faint white line, or have one side be a bit flat. Which is positive is anybody's guess, but that is where the multimeter comes in. OTOH, with LEDs, if they light up, you guessed right. If they don't, switch the wires. No big deal.
- Ishkabibble
Now all I have to do is find some place around here where I can get five pieces of 1" x 5" x 0.060 steel strips.
Everywhere I've gone around here said "We ain't gots no scraps, but I'se kin sell ye a whole sheet and cut em fer ye. Whatcha makin ennyway?"
Nothing that would require that kind of a purchase, my toothless friend. And a whole sheet is 48" x 96". A couple hundred dollars for five damn little strips.
I'm having another mental block here.
- Alibally
honkerman wrote:This gets a bit more complicated in a motorcycle harness...Unless it's a Harley, then, like I said before, most of the wires are black. Good times right there.Mel46 wrote:Here is a way to always know which is hot and which is ground...if the wires are red and black...I used this in aircraft electrical school to remember.
Red to black and blue to f**k
- GeorgeSK
- Color: Both Red
Must you have steel? You can get hobby brass at a place like Michael's or AC Moore (arts and crafts places) If you can stand upping the thickness, HD ( and very likely your good old fashioned local hardware store) has steel flat stock 1/8" x1/2".
If you can suffer a material change to aluminum: http://www.homedepot.com/p/Everbilt-1-2 ... /204604762
You could also use flat stock: http://www.mscdirect.com/product/details/06200059 1/16 is only 25 thousandths bigger than you ask for. Another possibility - wait until school starts and get the machine shop students on it.
A last, out of the box idea - what about a bit of hack saw blade? So long as you don't need to drill a hole in it, you are all set.
- Ishkabibble
Actually, I need to drill three holes in it.
I have a clipboard made of aluminum that is just over 0.060. I figured it would be about the right weight and thickness to make a bracket out of, and wouldn't be too terribly affected by the vibration of riding. Steel would be ideal, but I don't know that I have the ability to work it at a size this small.
The bracket has to fit on the bottom of the running light, as the light has a hole at each end, and the reflector bracket has one hole in the center. In order to use a bolt to attach the running light bracket to the reflector bracket, it has to have a hole in the center. The reflector bracket has to have a hole in each end to attach to the running light.
Like this:
Like this:
- bracket2.png (216.36 KiB) Viewed 1806 times
