After noticing my number plate rattles during warm-up, I stuffed a tissue in behind it as a temp fix before my test ride.
The second thing I noticed was that the bike was still noisy, this is because I've removed the outer airbox snorkel.
The next thing I noticed is that the bike lost some power. I didn't reset the ECU, so it's that or the a/m made some power?
I'm going to be putting the outer snorkel back in the airbox as it made no difference to performance other than added noise...
While the a/m exhaust is off I'm going to buy some exhaust wool and stuff it into the cannon with some mesh to secure it.
I'm hoping this will cut back some noise without blocking the exhaust or melting the mesh then blowing the wool past the baffle.
Just to amuse myself I might remove the baffle from the a/m exhaust and see how loud this sucker really is!
I never did work out where that vibration/scrubbing noise is coming from...
