Gators bike is showing PCX150 2015/16 stock LED headlamps in the low beam position. The spider on the windscreen is not stockjayjayslim69 wrote:What kind of headlights are those? Love the whiter color.GatorGreg wrote:Excellent vid homie - you have very tasteful mods!
Here's my favorite pic of, er, oh my God, I haven't named my PCX yetAnyway, here she is on her way to a Halloween party
Show those beautiful PCX's
Re: Show those beautiful PCX's
- image.jpeg (131.75 KiB) Viewed 4620 times
jayjayslim69
Thanks for the reply. I'm looking to switch over to LED bulbs on my 2011 PCX125 (if it's even possible), but I am having trouble finding the correct bulb size. I plan on installing additional LED light bars on it and want the light colors to match. I would hate to have the dingy halogen bulb color mixed in with the cool blue LED bulb color.homie wrote:Gators bike is showing PCX150 2015/16 stock LED headlamps in the low beam position. The spider on the windscreen is not stockjayjayslim69 wrote:What kind of headlights are those? Love the whiter color.GatorGreg wrote:Excellent vid homie - you have very tasteful mods!
I believe you might find something in the archives here but this was before my time with PCX. I can tell you that when I installed LED's on other bikes you need a resistor in the mix and a different flasher as the turn signal will be very fast until you slow it down with the proper rating. It's going to be a project for you i'm sure, why not consult your dealer and just harvest the parts and procedure with cost estimates before you set out on your own.
Homie, where did you acquire and what are the specs of the Vario Kit/items you purchased? VERY nice looking PCX. Love your ride. Thx
2015 PCX 150, YSS Shocks (XL), NCY Roller Weights (20x15- 13 gram), NCY Vari (Item# NCY-1029) and NCY Face (#1200-1193), TyreBeads- motorcycle balancing beads
find the vario parts here http://www.hondapcx.org/viewtopic.php?f ... azon+homieKriden wrote:Homie, where did you acquire and what are the specs of the Vario Kit/items you purchased? VERY nice looking PCX. Love your ride. Thx
See the parts here https://www.youtube.com/watch?v=-NRc9g3Dasw
who dosent like trains?
and graffiti
and graffiti
- easyrider
- Color: blk
Where did you get the tank bag..brand, model number etc ? .. Looks nice and handy.. appreciate info ..Thx
Marsee, I can't link you to it because its an older discontinued model sorry. The Marsee is a quality product but you would have to check the dimensions of the new line closely. We have a limited space to fill on PCX. Expect to pay a buck and a half for Marsee tank bags.easyrider wrote:Where did you get the tank bag..brand, model number etc ? .. Looks nice and handy.. appreciate info ..Thx
- onemac
I love my PCX so much that i own 2 of them :-)
One was for Sale, Sold now
still a lot of work to do
- 20160824_103347.jpg (271.04 KiB) Viewed 4362 times
Current Bike(s)~ (Casper) 2019 Honda Forza 125
Previous Bikes ~ (Rosie) 2018 Honda CB125R : (Stumpy) 2017 Honda MSX 125 (Grom) : (Ghost) 2016 Honda PCX 125 : (Lillith) 2016 Honda PCX 125 : (Gizmo) 2015 Sinnis Apache 125
JustScootIn
- Year: 2015 PCX 150
JustScootIn
Matte black front fender
Matte black front grill
Matte black rear fender and rear fender piece
Matte black left and right lower side panels
Found at bikerzbits.com (Thailand)
Malossi exhaust w/o db killer
Found at scooterpartsco.com (USA) shoutout to jge64 got idea for this part from his build thread
6 12" Winplus Type S Plug and Glow multi color LED strips. color changing and other settings controlled by app via Bluetooth to the smart hub which plugs into the 12v socket.
Found at my local AutoZone.(North America).I bought the starter kit which came with the four 12" strips, two 48" cables, two 100" cables, the smart hub which the cables plug into, and the 12v power plugin. Also comes with wire so you can hardware it. I bought two additional 12" strips and some 24" extensions which are connected to the lights under the floorboards. Cool easy lighting for less than a 100$
JustScootIn
Oh and a ADIO Honda pcx 150 fender eliminator from webike (Japan)
- Year: 26 adv 160
Love the black panels you have added, I've done the front and might do the lowers like yours. Still think the malossi pipe is more upscale than any other that I've seen, I have run the db killer in and out andfor my neighbors, mostly keep it in. I painted the down pipe from the engine flat black too, looks much better.
JustScootIn
Thanks I love how the two toned look has turned out. As for the pipe I couldn't be more pleased with it. I hadnt thought to paint the header pipe but its' brassy color does not really bother me. I actually kind of like it.
- Year: 26 adv 160
After a year or so mine turned from the brown brassy color which was OK, to a multicolor/dirty look so the flat black worked out good
JustScootIn
Oh that does look good! Very clean bike!
I am not sure if you have posted about your seat elsewhere, but how do you like it? It is very similar to mine, and I have never regretted buying it.Jge64 wrote:After a year or so mine turned from the brown brassy color which was OK, to a multicolor/dirty look so the flat black worked out good
I ran across this totally wild ONE FIFTY concept 2012 PCX:
http://www.mocyc.com/modify/541/ONEFIFT ... EITFOREVER
