2013 PCX 150 changing odometer KM to Miles and vice versa
ScottDR
Post by ScottDR »
Hi all,
Is this possible? I did a lot of searching so my apologies if that information is on this site.
Thanks in advance!
Scott
2013 Black PCX 150
Mods/accessories:
Previously owned:
1975 Honda CB125
1986 Kawasaki Ninja 250r
Re: 2013 PCX 150 changing odometer KM to Miles and vice vers
On my U.S. model the kph is smaller and is under the mph, which is printed in larger letters. As far as the odometer part in concerned, I don't see how you can change that without changing the entire speedometer.
Alibally
Post by Alibally »
I don't think you can change it.
Sent by carrier pigeon.
Not sure if the US / Canada models follow UK 'E' standard or align to the European models 'ED', but for UK 125's, with average fuel used displayed you press and hold the mode switch for mode than 2 seconds and you can then select between four things - mile/g, mile/l, km/l or l/100km. If km/l or l.100km are selected the trip and odometer show km's if mile/g is selected then they show in miles. May be worth a play?
Who cares. Slow is slow. It's a scooter
The only way I know how is to swap you present instrument panel out for one like this, which I did.
PCX Speedometer.jpg (146.02 KiB) Viewed 3705 times
ScottDR
Post by ScottDR »
Ok, thanks all. I figured as much but thought I had seen it on this forum. Maybe what I read was for the Forza (it was late at night, could have been :).
Thanks again. Hope to make the 12 hour ride to Ohio and back on Friday to title/register it.
2013 Black PCX 150
Mods/accessories:
Previously owned:
1975 Honda CB125
dkazzed
Year: N/A
Post by dkazzed »
I thought the OP was asking about the odometer which is the cumulative distance traveled?
2015 Honda CB300F ABS
dkazzed wrote:I thought the OP was asking about the odometer which is the cumulative distance traveled?
They were - which for UK models at least, and from my post, changes from km's to miles if you change the mpg from L to G.
