Can I put a honda forza 125 gastank onto my pcx?
chasmon
Hello,
My gastank is stuk and I've to put a new one. So perhaps the gastank of the honda forza 125 also fits into my honda pcx 2015. Anyone an idea if this works?
- Alibally
Re: Can I put a honda forza 125 gastank onto my pcx?
I wouldn't think so. It's a different bike altogether. You might get a second hand one on eBay.
- honkerman
The only way to know for sure without trying it is to check the part number. I'd use cheapcycleparts.com to look it up, but the Forza 125 is not a US model, so they don't have it on their database. Anyway, if the part numbers are the same, it will work, if not, it won't.
- honkerman
Cracking plastic perhaps?homie wrote:Just curious how does a gas tank fail exactly?
It's "stuk", silly.homie wrote:Just curious how does a gas tank fail exactly?
yes, I was working on the definition of 'stuk' from him with a little sensitivity to his slangchicaboo wrote:It's "stuk", silly.homie wrote:Just curious how does a gas tank fail exactly?
Apparently its Dutch for broken.
https://en.wiktionary.org/wiki/stuk
The Forza 125 tank only fits in a Forza 125.
Same for the 300.
Same for the 300.
chasmon
@Homie well, its very simpel. There is someone who is very pissed off at me because I'm dating his ex and that person has made some serious damage on my bike. He made some holes into my gastank and my bodywork. The bodywork I can repair but not the gastank.
And yes stuk comes from dutch and it means broken
Thanks to everybody who replied and tried to help me
. I'm going to contact the supplier and ask him if the fixing bolts are at the same place or not and if it would fit into my pcx.
Ah... Chief say "some of us have been there."
Well this will be our first gas tank replacement thread... I think. Hope we can get a 'how too' video or maybe couple images of the procedure.
- mac&chief2.jpg (10.11 KiB) Viewed 3285 times
chasmon
I wanted to beat the crap out of that person but if I do so, its me that's going to prison and he is really not worth it. I've sent a message to www.bike-parts-honda.com and ask if they have the same fixing points as my pcx. If not, I've got to order the pcx gastank. I'm going to put ' a how to' tutorial when I get my tank
chasmon wrote:I wanted to beat the crap out of that person but if I do so, its me that's going to prison and he is really not worth it. I've sent a message to http://www.bike-parts-honda.com and ask if they have the same fixing points as my pcx. If not, I've got to order the pcx gastank. I'm going to put ' a how to' tutorial when I get my tank
Excellent
Just out of interest how did he get holes in the tank. Drill?
Won't your insurance cover it?
chasmon
Indeed,he did it with a drill. In the middle of the night. And when I came out to see, he ran away like a pussy. My insurrance covers everything, but since I've to put a new one on it, I would go for a bigger tank.
The only way of getting a bigger tank is to have an extra bit welded onto the existing one.
You could get the holes welded...
Careful though, welding petrol tanks is a hazardous job.
brought a drill to a potential gun fight in my townchasmon wrote:Indeed,he did it with a drill. In the middle of the night. And when I came out to see, he ran away like a pussy. My insurrance covers everything, but since I've to put a new one on it, I would go for a bigger tank.
chasmon
Well, I've got an answer and he can't confirm that it will fitt. So I 'm going to ask a buddy of mine at the end of this month to weld a new gastank that fits in our precious. I'll keep you informed
The gas tank is plastic and pretty easy to either plastic-weld or repair with an epoxy.
Be careful getting a different tank because you have to fit your petrol pump into it.
Good research GN2gn2 wrote:Apparently its Dutch for broken. https://en.wiktionary.org/wiki/stuk
This is also an affirmation to all of us for including our location with our profile ... even if it is just the country. It helps us when we respond. And in this case, just because a Dutch term is used, doesn't mean he/she is living in the Netherlands.
chasmon
No I'm not living in the Netherlands but in Belgium
