Left CrankCase Cover Torque Values
When replacing the Left Crankcase Cover there are 11 6mm bolts of varying length. I can't find the proper torque spec. I tightened to 9ftlbs but that just doesn seem tight enough.
What torque value should I use?
Thank You
Thank You
- Alibally
Re: Left CrankCase Cover Torque Values
When you say the crankcase cover do you mean the belt cover or the actual main crank cover?
The aluminum belt cover. Part number 1 here:
http://www.partzilla.com/parts/search/H ... parts.html
The bolts are numbered 14, 15 17
Just do it by hand, there's no need for a torque wrench for bolts like that.
j.d.b.
- Color: red
How tight is tight?
j.d.b. wrote:How tight is tight?
How high is high?
Thanks gn2gn2 wrote:Just do it by hand, there's no need for a torque wrench for bolts like that.
- Alibally
I had a look in my pcx manual to get a guide and there isn't a torque setting listed as far as I can see. What you've torqued it to will be fine. They don't go that tight
Agreed... I did not see a torque for the belt/vario cover either. Just a healthy twist about equal to tightening your cars fuel cap in a staggered pattern of your choice.
Opp's Forza chat... again
that darn 'view new posts' tab I'm going to stop using it
Thanks All....
MBMyer
I find the SM unclear on this point. Page 12-4 has no specific torque values on these 11 bolts. Page 12-5 refers to them as "Bolts (8 mm head)," and there seem to be the correct number of the circled in the picture.
Looking back at the general torque values on p. 1-11, I see an entry for "Left crankcase outer cover socket bolt" with a 6 mm thread and a torque value, but there are only 3 of them. In the chart of standard torque values above this, I see two different 6 mm bolt & nut values and yet another for a 6 mm screw.
Comparing with the parts list (cf. link above), I believe that the values we are supposed to use are for the "6 mm flange bolt (include NSHF)" despite the "nut" being built into the scooter.
Yes? No?
Yes? No?
- Screen Shot 2016-06-12 at 6.12.50 PM.png (332.21 KiB) Viewed 7650 times
- Screen Shot 2016-06-12 at 6.18.45 PM.png (291.37 KiB) Viewed 7650 times
6 other previous bikes
- Alibally
There's a plastic cover that bolts onto the crank cover with 3 bolts. It may be them.
