New Air-Horns for the Forza!
pullin_gs
Post by pullin_gs »
These things are so loud THEY SCARE ME when I light them up!
I bought the kit (included horns, compressor, relay) for about $15.
Wires, stainless screws, connectors, extra plastic hose cost me another $10.
Total install time (glass, paint, custom mounting, wiring) is between 3 and 4 hours.
On my other bikes, I mount the trumpets directly to my fairing as is without mods.
However, these are mounted on the wheel-side of the front forks of the scooter (lots of vibration).
I had to "glass" the trumpets with two layers of fiberglass cloth and resin (5-minute epoxy) because of lateral force exerted at the horn base due to Washington DC pot-holes.
The compressor lays inside the space over top of the left storage compartment right undernieth the plastic cover that is held on by two screws.
I wired the compressor and relay directly to the battery terminals with 16awg copper wire with a 30-amp fuse (15 amp fuse blows). The wires and plastic hoses all fit nicely between the red plastics and bike's inards.
The horn relay's coil wires up directly (in series...I kept the original horn) to the existing horn.
Advice:
DO NOT let horns get water inside them. Horn will rust and quit working.
DO NOT mount compressor close to the ground where the air inlet will suck in dirt. This will ruin the compressor.
Done!
montliz44
Year: 2013,2014
Color: red+redder
Re: New Air-Horns for the Forza!
Post by montliz44 »
All rightie then, that is some serious hornage right there. Love it!
Johnny
This is the horn that I bought for our bikes. They are compact and easy to hide.
https://www.hornblasters.com/products/d ... e-air-horn
pullin_gs
Post by pullin_gs »
Mel46 wrote:This is the horn that I bought for our bikes. They are compact and easy to hide.
Very nice....thanks for posting the link.
My main issue with the route I took is that the trumpets do not hold up to the elements well.
Water will ruin them (WD40 sprayed periodically into the horn helps though).
Have you had good luck with these?
Aren't these positioned so that water is likely to get into the horns?
Year: 26 adv 160
Really could not go with that look if it was my bike.....maybe half that size.....maybe......
pullin_gs
Post by pullin_gs »
Jge64 wrote:Really could not go with that look if it was my bike.....maybe half that size.....maybe......
I have to admin that my priority to "go with that look" was not even a factor when I chose these horns. :)
When it comes to my safety gear (They call me the Glowing Anti-Squid!) aesthetics really does not matter to me.
pullin_gs
Post by pullin_gs »
you you wrote:Aren't these positioned so that water is likely to get into the horns?
When sitting still, yes. Moving it matters not.
I wonder if the expensive stainless horns have stainless 'inards also???
just waiting for the sound video... where?
davenowherejones
Color: Silver
Post by davenowherejones »
I got cut off by some asshole so I hit the horn good & loud. I caught up to the guy and it was my next door neighbour. The old guy has dementia.
Loud horns don't cure dementia.
davenowherejones wrote:I got cut off by some asshole so I hit the horn good & loud. I caught up to the guy and it was my next door neighbour. The old guy has dementia.
Does it sound like this
