Radiator cover
lolofigo
Year: 2012
Color: Silver
Radiator cover
Post by lolofigo »
I've had red temp warning light on so decided to bleed cooling system as I might not done it properly after reasembling the engine. There is plastic cover on the radiator that blocks access to the radiator cap. No big deal as it's only held in place by three bolts but to get to the bolts and to have space to move that stupid cover out of the way whole botom panel has to be removed. To save the time doing it again in the future I took my trusty dremel and cut the bastard thing.
Re: Radiator cover
Smooth, top tip
Year: 26 adv 160
Re: Radiator cover
Hmm, how often do you think you'll have to get to that cap?
Ill stick with removing the plastic trim....
lolofigo
Year: 2012
Color: Silver
Re: Radiator cover
Post by lolofigo »
Jge64 wrote:Hmm, how often do you think you'll have to get to that cap?
. That's my old Honda scv 100 lead. Three bolts to get all the plastic out of the way. Whole seat and plastics around it were on the hinge. But pcx is just doing my head in.
Re: Radiator cover
Would be great if the pcx was like that
Re: Radiator cover
It's not too bad! Look here instead of cutting: http://hondapcx.org/viewtopic.php?f=3&t=2630
