get more rear view in mirrors
If you loosen the two small bolts (7 or 8mm?) holding each brake handle/brake fluid reservoir in place....you might be able to slide this out on the.handlebar and gain some extra imaging in your mirrors. Do not bind the levers or over extend the brake lines...but I gained an extra half inch with my mirrors...and it made a difference! I also leveled my reservoir and now get a more accurate bubble in the check window.
Ishkabibble
Re: get more rear view in mirrors
Post by Ishkabibble »
I may have to try that...
Doing that will probably give you the same results as adding the Givi kit that moves your mirrors out about 2 or 3 inches. I have the extenders on both of our bikes and it makes a world of difference. You can actually see something other than yourself once they are moved outward!
Ishkabibble
Mel, the only difference is the kit costs, while the position adjustment doesn't... :lol:
And some of us think the extenders look goofy.
I replaced the Forza mirrors with OEM Honda CB500X mirrors....which look exactly like the Forza mirrors but with effectively longer stems. Results look stock/OEM. Honda shoulda' used them on the Forza !!
MBMyer
Post by MBMyer »
Forza & CB500X mirrors.jpg (1.15 MiB) Viewed 7251 times
Here is a side-by-side of the stock Forza 300 mirror (top) and the stock CB500X mirror (bottom). It was a very easy swap, but not free (as sliding the hand control units would be).
6 other previous bikes
fish wrote:If you loosen the two small bolts (7 or 8mm?) holding each brake handle/brake fluid reservoir in place....you might be able to slide this out on the.handlebar and gain some extra imaging in your mirrors. Do not bind the levers or over extend the brake lines...but I gained an extra half inch with my mirrors...and it made a difference! I also leveled my reservoir and now get a more accurate bubble in the check window.
Thanks for the pm. Can't reply for some reason
Sliding things around is free, but gains you only fractions of an inch..
CBX mirrors give much better view.
dasshreddar
Year: forzaruckuspcx
Post by dasshreddar »
fish wrote:Sliding things around is free, but gains you only fractions of an inch..
I agree, but if your cheap just bend the stock forza mirrors in a shop vise.
Ishkabibble
I like those mirrors though... Do you have a photo of the back (non-mirror) side?
Road-Dog
Post by Road-Dog »
Or you can just cut the OD 3/8" pipe and add a 6" 3/8 ID pipe like I did. I also painted it black so it looks factory.
That is a good idea
