Crankcase breather tube - Difficulty in removing plastic
Sasso
Post by Sasso »
Hello everyone ...
I have a 2015 PCX150.
This may sound stupid but I literally cannot remove the crankcase breather tube.
I've loosened the metal tightener thingo, and try as I might with fingers, tweezers, pliers, twisting, pushing, squeezing.. I cannot remove the bloody thing!
I've tried getting a wire or bent tweezer into the top to try and pull the top down first as I thought maybe it was just sticking to much to the black plastic part.. but no. I've pulled hard on it with a set of pliers... and so on...
So ultimately I figure I could ask this question here... Has anyone experienced difficulty in removing it like I am?
The funny part is I took it to get the 4k service done, and they changed the engine oil but did not cleanout the crankcase breather... I don't mind the oil but as I am rather mechanically "inept" at the moment though slowly learning, I hoped they would remove the simplest and yet most frustrating part!
Anyway hope someone can help with a method of solution... :D :oops: :|
Re: Crankcase breather tube - Difficulty in removing plastic
Maybe some dish detergent squeezed around it might loosen it? And Hey! What about a hair dryer? "Warm" the plastic tube and pull it off?
Or get mean (arg) grab a pair (haha) of pliers, put a cloth on its jaws and take a hold of the tube
Best I got to offer. Good luck and
Report back with how you got it off...okay?
Sasso
Post by Sasso »
Thanks for the suggestions. I tried the pliers (without the cloth though) and pulled quite hard but I am afraid to break the tube.
Didn't think about the blow dryer or detergent idea though.
Will do. :)
waspmike
Post by waspmike »
This right?
Part #5
You have to spread the spring clip (#14) and slide it back along the tube. If you have done that insert a large screwdriver between the end of the tube what is next to it and twist the screwdriver.
Sasso
Post by Sasso »
iceman wrote:A bit like this - https://www.youtube.com/watch?v=MFlH57ahtbo
The "simply wriggle and pull off" part is the part that doesn't work for me.
It's quite stuck on.
Never removed mine - now on 7600 or so miles. Looks empty but dirty. Will try and clean it at some point - but gave the bike a bit of a clean yesterday (1st time in 3 months).
Sasso
Post by Sasso »
I understand it's not the most urgent maintenance job, just wanted to start somewhere (the other place i started is breaking some plastic clips on the rear grip handle cover! :D) in terms of learning about the bike and each part etc.
anyway willl try blow dryer tomorrow and report back.
Sure sasso, I'm with you. Clean bike, happy bike. I'd want that oil out too.
Below, I think I see a drip in mine. Not ready yet. (And some street dirt dust...oh noooo).
For those who don't know what part we're referring to, it's the clear plastic (breather) tubing you see here:
iceman, I liked that video. Short and to the point. Now if sasso can get his off, all will be good! :P
That's what we are having trouble with :oops: this is .... sad
WhiteNoise wrote:Sure sasso, I'm with you. Clean bike, happy bike. I'd want that oil out too.
Is that tube sealed on the end? or do you just squeeze the end so that it opens - then let it drain?
Sealed. You must remove it
homie wrote:That's what we are having trouble with :oops: this is .... sad
Perhaps he/she is trying to take the bike off the tube rather than taking the tube off the bike.
Entirely understandable then isn't it. Feel silly now?
well no... WN is soaping it up and you have waspmike in here with the exploded view and a spring clip tool. Maybe we heat it up with a torch and set the whole bike on fire :lol: ... just pull that off already... please.
Mister Paul
Post by Mister Paul »
Our dealer pulls it off with pliers on the metal clasp, then blows it clean with the air pipe.
If you really want to get it off, why not buy a spare in case you damage it? Then just tug away.
now Paul is blowing and tugging on it... ridiculous
Sasso
Post by Sasso »
woowoobeebee
waspmike
Post by waspmike »
Sasso wrote:woowoobeebee
..and was it the crankcase breather or the drain tube. How did it come off?
homie wrote:Feel silly now?
well no... WN is soaping it up and you have waspmike in here with the exploded view and a spring clip tool. [/quote]
I'mf getting like GN2, here. The more accurate the question, the more accurate the answer can be!
^ I Second that! ^ You Are! :lol:
That's a good thing though! ;)
Okay sasso, fess up, job done? Tube off? Tell us what worked mr. woowoobeebee :P
