http://andrewcharnley.com/?resources&module=view&id=344
![Image](http://andrewcharnley.com/objects/resources/344/thumbnails/resourcesview.jpg)
http://andrewcharnley.com/?resources&module=view&id=342
![Image](http://andrewcharnley.com/objects/resources/342/thumbnails/resourcesview.jpg)
http://andrewcharnley.com/?resources&module=view&id=340
![Image](http://andrewcharnley.com/objects/resources/340/thumbnails/resourcesview.jpg)
The tyre is fine, so is the suspension.snoopy wrote:4. it may be the rear tyre or the weak suspension but if leaning too much on a corner the tyre looses it causing a brown trouser moment.
Hopefully you can hook up at a safe distance behind one of the trucks that is moving at a speed you can hold and follow them so that any of the other vehicles trying to over take you, will plan to go past them as well.snoopy wrote:3. the 55mph GPS top speed (62.5mph restriction) is dangerous on motorways where the restricted lorries at 56mph crawl past and try to get in too quickly.
You know what they say about bad workmen and their tools...snoopy wrote:It can only be the tyre
I am using this one.qed wrote:Where did you get the Iphone mount from? Its exactly what I'm looking for
sendler2112 wrote:I am using this one.qed wrote:Where did you get the Iphone mount from? Its exactly what I'm looking for
http://www.amazon.com/Arkon-GPS032-Hand ... ebar+mount
