pcx alarm does not have sound...
up to 1000 km mark alarm works fine til today. after that when alarm is set, disarmed and answer back has no sound only lights blinks but when it sense vibration it has sound. i am new to this so please help me out here.
- Year: 26 adv 160
Re: pcx alarm does not have sound...
The first place I would check the is the speaker, but you will need a continuity tester. Check the speaker conn cation.
'but when it sense vibration it has sound' so it seems speaker is ok but not working for all modes?Jge64 wrote:The first place I would check the is the speaker, but you will need a continuity tester. Check the speaker conn cation.
yap when vibration is there it has sound so i think speaker is ok. something i found out today it before my remote blink in yellow when it is press but now it blinks in red color. so i found out that alarm went mute because of the remote. how its works fine. thanks for fast reply.iceman wrote:'but when it sense vibration it has sound' so it seems speaker is ok but not working for all modes?Jge64 wrote:The first place I would check the is the speaker, but you will need a continuity tester. Check the speaker conn cation.
- wangsuda
So how do you get the sound back on? Mine suddenly went dead as well. The only time it makes noise is when I shake the bike with the alarm on. But that is it. How do you get the set and unset and answer back sounds on again?
- wangsuda
Did look before I posted. Doesn't work. Next stop is the dealership.
- Color: silver
did you try hold answerback button for few seconds ??
- wangsuda
You, sir (or madam), are a gold-plated genius! Thank you!nhatientri wrote:did you try hold answerback button for few seconds ??
