2014 Honda Forza 300 Won't Start
davenowherejones
My Honda Forza 300 will not start. It is on the genre stand. I turn the key. I grab the left brake. I push the start button. It turns over but it will not start. I last rode the scooter on September first.
Has the gas gone bad in that little time?
Dave
Hope, BC, Canada
Dave
Hope, BC, Canada
Re: 2014 Honda Forza 300 Won't Start
Waranty i guess.
davenowherejones
I bought it used. How long is the warranty?dadragon wrote:Waranty i guess.
davenowherejones
AUTOCORRECT SUCKSdavenowherejones wrote:My Honda Forza 300 will not start. It is on the CENTER stand. I turn the key. I grab the left brake. I push the start button. It turns over but it will not start. I last rode the scooter on September first.
Dave
Hope, BC, Canada
You wouldn't have happened to hit the kill switch by accident maybe? I've done that already and it took me a while to figure out that I bumped the switch.
- Year: 26 adv 160
Yup.......waybar wrote:You wouldn't have happened to hit the kill switch by accident maybe? I've done that already and it took me a while to figure out that I bumped the switch.
Mister Paul
Been there. Also done the panic at the petrol pump when it won't start, without realising that the side stand was still down.waybar wrote:You wouldn't have happened to hit the kill switch by accident maybe? I've done that already and it took me a while to figure out that I bumped the switch.
- JohnL
- Ozzie Old Fart
- Color: Dark Red
You all make me feel so much better.
davenowherejones
OK on the kill switch. If the kill switch is on then the motor will not even turn over. The motor turns over but is probably not getting any gas or the gas is bad. It is about 7 degrees C right now. It is supposed to be warmer in a few days. I might charge the battery some and try later. Or I might suck the gas out and put fresh stuff in.waybar wrote:You wouldn't have happened to hit the kill switch by accident maybe? I've done that already and it took me a while to figure out that I bumped the switch.
Just got home from the eye doctor so my pupils are real big.
davenowherejones
Side stand is up.Mister Paul wrote:Been there. Also done the panic at the petrol pump when it won't start, without realising that the side stand was still down.waybar wrote:You wouldn't have happened to hit the kill switch by accident maybe? I've done that already and it took me a while to figure out that I bumped the switch.
davenowherejones
I had that problem when I was trying to get out of the way of the local police.Mister Paul wrote:Been there. Also done the panic at the petrol pump when it won't start, without realising that the side stand was still down.waybar wrote:You wouldn't have happened to hit the kill switch by accident maybe? I've done that already and it took me a while to figure out that I bumped the switch.
A car was in the ditch.
davenowherejones
OK, Thanks for all the suggestions. The FORZA RUNS. I charged up the battery a little more and cranked the hell out of it. It started.
Does taking the key out so that the key magnets are far away actually help?
I probably took a year of life from the starter. I am not sure how much the 7 degrees C actually mattered. The oil seemed to flow from the dipstick. Needs an oil change.
I am in withdrawal and its only been a dozen days since I rode last. March is going to be agony.
SteveP
- Color: red
The temp may have an effect. It would if the motor was carbureted, but would think the fuel injection would make the starting easier in cold weather. Haven't tried my Forza at temps much below upper 40'sF. You might try laying a lighted 100 watt light bulb (or even 75 watt) under the scooter below the oil sump and draping a blanket over the scooter to help contain the heat within the engine compartment. Might help.davenowherejones wrote:OK, Thanks for all the suggestions. The FORZA RUNS. I charged up the battery a little more and cranked the hell out of it. It started.
davenowherejones
I wonder if anyone makes a dipstick electric oil heater? Trying Google next.SteveP wrote:The temp may have an effect. It would if the motor was carbureted, but would think the fuel injection would make the starting easier in cold weather. Haven't tried my Forza at temps much below upper 40'sF. You might try laying a lighted 100 watt light bulb (or even 75 watt) under the scooter below the oil sump and draping a blanket over the scooter to help contain the heat within the engine compartment. Might help.davenowherejones wrote:OK, Thanks for all the suggestions. The FORZA RUNS. I charged up the battery a little more and cranked the hell out of it. It started.
When my Forza has sat for a week or two it needs a bit of throttle to start.
davenowherejones
Yeah, that helped as well. I am wiring in a socket to put a 2 watt solar charger on the battery for all winter until March. I took the seat off to get my head in to see the battery. I am not sure if I will re-attach that stupid little barely functioning strut back on the seat. I want to look to see if the seat can be made to open further with a bit of grinding.gn2 wrote:When my Forza has sat for a week or two it needs a bit of throttle to start.
It was -5C here but it has warmed up to +5C today with a forecast of 50 mm of rain for the next 24 hrs.
I hook up a battery tender to mine over the cold months and don't disconnect it until warmer weather. I don't ride during the winter months. These batteries like to have a full charge.
- GeorgeSK
- Year: 13PCX,15Forza
- Color: Both Red
I'll be interested in your experiments with the seat. So far, the seat cover opening for the oddly shaped storage compartment is the only flaw in a great machine, but I find it glaringly annoying (along with the helmet hanger - PCX has Forza beat hands down in these two departments).
- E. Foster Salsbury
- Year: 2015 NSS300A
The oddly shaped storage compartment is a small sacrifice to have that "ride-in" feel and low seat height of this great machine. IMO
Salsbury
Mister Paul
What's up with the helmet hanger? I rarely use it as there's normally plenty of space under the seat or in the topbox, but if that's all full it's a useful addition so that I don't have to carry my helmet around with me.GeorgeSK wrote:I'll be interested in your experiments with the seat. So far, the seat cover opening for the oddly shaped storage compartment is the only flaw in a great machine, but I find it glaringly annoying (along with the helmet hanger - PCX has Forza beat hands down in these two departments).
