Oil strainer cap part number?
proteinsdef
Anyone know the part number (UK) of the bolt you remove when cleaning the oil strainer basket? I managed to round it when removing it and need a new one for the next service.
Ta
Ta
j.d.b.
- Color: red
Re: Oil strainer cap part number?
Are you asking about the cap over the strainer with the o-ring on it or the bolt retaining the P-clip to the crankcase holding the rear brake cable(just above the strainer cap)? The title of the thread sounds like you damaged the cap, itself, which is not a bolt. The question asked sounds like the bracket bolt is the trouble.
The manual doesn't call out the cable bracket bolt, at all. Likely you'll need to ask the Honda dealer for either part it. I don't see them available in a few on-line searches, thus far.
- Oyabun
- Year: `12,`15,`19
- Color: black&black
For future reference you can find the parts catalog provided by Dem0nk1d and posted and hosted by Maddiedog here:
http://hondapcx.org/viewtopic.php?f=19& ... umbers+pdf
I have found it in the microfichie (page 44 item no. 6) this:
2361-035-000 CAP, TAPPET ADJUSTING HOLE
- yak
- Minister of Magic
You aren't the only one to round that bolt.
It seems like the oil strainer only needs to be cleaned once. No one has reported any debris in it during later oil changes. Most people didn't find any debris during the first inspection. There are a few photos on this site of some metal pieces caught by the strainer as well as one person who found blue plastic bits.
yak wrote:You aren't the only one to round that bolt.
Couldn't agree more more. Change the oil but after a couple of changes the strainer doesn't pick up anything.
Hi proteinsdef, my suggestion is to search eBayUK with: Honda scooter GY6 kit (or similar wording). Several of us have ordered this kit in the U.S. (as a backup). It's cheap enough.
proteinsdef
Hi chaps. Thanks so much for the info. Its the bolt that holds the actual basket in place and has the o ring in it. The bolt holding the brake cable is fine. I think the issue is that its so shallow and there is nothing to get hold of. I had to use special wedged sockets in the end just to get it off and as you both said there was nothing in it!
Not sure what you used but never use 12 sided sockets for six sided bolts. 12 sided are nasty things and prone to stripping 6 sides bolt heads when there is not much grip or only a shallow depth to fit over.
proteinsdef
Just used a 17mm Spanner but it couldnt get enough of a grip. Had a look on Ebay and they have them on there from the US, about £14 all in so will order it next time its due for its service. The cap was solid when trying to get it off so wondering if the Honda dealers cranked it on last service?
Disagree.
Remove the cap and clean the three parts (screen basket, spring, cap,) and reinstall as scheduled in your manual.
Do not over tighten.
Your scoot has no renewable filter for the oil, but this one.
Once removed darn near any tool will essily remove it if you do not leave it on there forever, and do not over tighten it.
Buy the set of GY6 parts on ebay for about $7....so if you mistakenly over do it....you've got a new spare.
I clean these parts every oil change....plus to ignore the screen means leaving some dirty oil in the engine behind that cap.
Once you get the cap off this thing off from its factory snug...there is no reason to pretend it's not there.
- Alibally
Remove the chamfer on a full hex 17mm socket and this grips the shallow hex on the cap so help stop rounding it.
See the example photo for what I mean.
- ImageUploadedByTapatalkHD1446013139.251129.jpg (74.95 KiB) Viewed 3692 times
