A FULL TANK
- pja2536
- Color: BLACK
A FULL TANK
I was out for a ride on my Forza this morning and needed to get some fuel. Whenever I fill the bike I take a great deal of trouble to get the last few mls of petrol into the tank; petrol is just starting to run out of the filler . That said, as I rode away from the filling station my fuel gauge indicated that the tank was just under full, halfway between 3/4 full and full.
While I've had the bike for quite some time this is the first time I've noticed this difference. Does the fuel gauge EVER show full?
I work on about 260 to 280 km per tank full, is that what others get?
Regards,
Peter
Regards,
Peter
Peter Anderson & Co.
"HE HAD offices in Sydney, not so many years ago,
And his shingle bore the legend 'Peter Anderson and Co.',
But his real name was Careless, as the fellows understood-
And his relatives decided that he wasn't any good."
Henry Lawson, August, 1895
Re: A FULL TANK
The gauge is only there for decorative purposes, use trip meter A and the economy meter for an accurate guide to tank range.
When filling do you use the sidestand or the centre stand?
I normally fill up around 170 miles (273km) and there's at least 1.3 litres left.
http://www.fuelly.com/motorcycle/honda/ ... gn2/234829
Re: A FULL TANK
Yup, mine says full when I fill it to the stop.
- Color: red
Re: A FULL TANK
Might be the way the controller updates the level. Try keying off and then back on. It's also possible the float is sticking or the trace that the sending unit touches is damaged or worn. The trip-meter is, indeed, the most accurate method as posted above.
Re: A FULL TANK
In general I would be more interested in accuracy at or around ZERO. Unless the tank is of uniform shape or there is a fancy algorithm in the circuit it cannot be linear anyway.
Re: A FULL TANK
Last time i refilled the tank it was after 292km, fitted in ~9.4 litres, (about 2 liters left I assume) that's about 3,2l / 100km.
Then the tank gauge showed more than full.
Wow! My first post actually
Honda Nss300 Forza 2014 - White
Re: A FULL TANK
Manual advises not to fill too far .. ...and you actually slightly over fill until it spills?!
Too far up the filler neck causes running problems on some scooters.
Re: A FULL TANK
Mister Paul wrote:Yup, mine says full when I fill it to the stop.
Re: A FULL TANK
I was wondering how many liters realy fits in the tank when it's completely empty.
Re: A FULL TANK
dadragon wrote:I was wondering how many liters realy fits in the tank when it's completely empty.
11.5
Re: A FULL TANK
That is what the manual said. But you can fill it up with more.gn2 wrote:dadragon wrote:I was wondering how many liters realy fits in the tank when it's completely empty.
11.5
And thats where I am curious about.
Re: A FULL TANK
The reason I know it takes 11.5 is because I ran mine dry once and it took 11.5 to fill it.
- GeorgeSK
- Year: 13PCX,15Forza
- Color: Both Red
Re: A FULL TANK
So what about empty? My gauge is reading empty and I still have 1US Gallon left. I can use the odometer and just refill at 150 miles or so, but since it is new, should I consider bringing it to the dealer for recalibration?
Re: A FULL TANK
No, they all do that -go straight from about a third into the red. I reset the odo every time I fill up and aim for about 180 miles.GeorgeSK wrote:So what about empty? My gauge is reading empty and I still have 1US Gallon left. I can use the odometer and just refill at 150 miles or so, but since it is new, should I consider bringing it to the dealer for recalibration?
