But no difference....
Anyway, I got a time at another place tomorrow, and then I really need to let the techie experience the 'rocking'
If it only does it at a steady, no load speed...could it be a fuel mixture problem, making the engine run slightly uneven? An air leak the fuel injection can't compensate for? A sensor that's not giving the fuel injection the correct info? Ignition timing varying for some reason?gogobert wrote:just sharing my thoughts here...One more thing, the bike needs to get in a 'static' state before the 'rocking' starts, meaning: No bumps, No breaking, No throttling, just an even speed above 35kmh at an even surface.
Feels like it need a little time to start oscillate...
I need to nail down the source that starts the 'rocking'
sure, I certainly will.j.d.b. wrote:Please post back on the results?
Hmm..as a minimum isn't that an elaborate solution to sorting out the symptom rather than the root causeBlackbeard1718 wrote:FWIW, take a look at Dynabeads or Counteract Tire Balancing Beads. I had 1 oz in each of my 12" Honda Big Ruckus Tires, and they ran smooth as glass. Good thing about the Beads, is that you can add them when you're getting New Tires, or through your Valve Stem, using their Kits provided. Also, if you already have Balance Weights on your wheels, it's fine, you don't have to remove them. I had 3K miles on my Tires when I Traded for the Forza, and never had any Balancing issues.
The 1 oz Kit should also do fine for each 14" & 13" Forza Tires. I used the Counteract Kit, which comes with 2 oz of Beads in 1 oz packets, Bead Bottle (Fill the Bottle with 1 oz of Beads at a time...), Tube to install the Beads, Valve Stem Core Remover, New Valve Stem Cores, and Valve Stem Caps.
Trick to adding the Beads: Use a Vibrating Tool, like a Dremel Tool, and place it on the Install Tube, as you're squeezing The Bead Bottle into the Valve Stem. The vibration makes the Beads flow like water, and takes a couple of minutes for each Tire. When you're done, pop the New Valve Stem Cores in, tighten them with the Valve Stem Core Tool, Air them up, Cap them off with the Caps, and RIDE!
Best of Luck!
Cheers!
BB
Ah, common problem with those trapezoidal tyres - the round ones are always bettergogobert wrote:The mechanic also notified that the old tire kind of moved up- and down a bit while spinning, and now it doesn't.
The egg shaped tires on my sister's jeep were not great either. Round is the way to go.iceman wrote:Ah, common problem with those trapezoidal tyres - the round ones are always bettergogobert wrote:The mechanic also notified that the old tire kind of moved up- and down a bit while spinning, and now it doesn't.- glad you got it sorted.
