rear tyre valve advice please.
dergav
- Color: grey
What could turn out to be the stupid question of 2015!
Got a new rear tyre fitted and got the garage to use a right angle valve to make inflating easier...
When I got back home I "thought" the valve would be better facing the other way for accessing it so I turned it round..Tyre immediately started deflating at the valve and even when turning the valve back it totally deflated...and now of course wont take being inflated....new flat tyre!
Was I just being stupid turning the valve or is perhaps something wrong in the fitting...before I return to the garage.
thanks for any advice ...and feel free to call me a numpty if thats what I have been!
cheers....
cheers....
Re: rear tyre valve advice please.
that is a very poor design if you only need to twist the stem to vandalize a vehicle... note to self never get those
thanks for the heads up and sorry this is your experience.
I'm guessing you turned it counter clock wise and it loosened the lock nut on the stem inside the tire which loosened the seal (o-ring or gasket) that's inside, outside or both. You may get lucky and try turning it back in the other direction to see if it will seal. If there is a nut on the outside just tighten that. I'm guessing not, since you probably would have tried. If it does start to tighten you're not going to have much choice as to where it finally seats though and you may tear the seal which also means game over. If it was me I'd give it a try, what have you got to lose it's flat already. If it seems to work have worked keep a close eye on your pressure for at least a few days. Google images of "right angle tire valve" so you have a good visual of what you are dealing with. Good luck.
Honda 2014 Forza 300 (ABS)
Honda 1995 Elite 80 (Sold)
dergav
- Color: grey
Atis
I think thats exactly what I did!!..previously on last bike I was likely turning only clockwise!...but didnt think of any significance..and it worked well..
Ah well....life is a big learning curve...at least I did it when at home and not out on a trip someplace!!
Dont know about in USA but I have found on the Forza in UK that at UK air pumps ( at least in Scotland) its well nigh impossible to connect the air pump to a straight valve...so had bought angles valve fitments to attach when putting in air ..but thought the fitted angles valve would be best when renewing tyre.
Have tried tightening clockwise but not making any difference so think I have knacked it......
Now to go get this blasted wheel off!!...again.
For £30 you can get a portable 12v powered inflator that weights next to nothing and you can carry with you on long journeys - I have one and it works a treat and has a very accurate gauge. Mine also came with a connector you can leave connected to the battery and you just plugged the inflator up when you like.
Works like a charm on my PCX (so Forza too?) and still uses the normal valve pointing inwards to the tyre hub.
Alternatively, once the tyre is inflated to the correct pressure, leave it alone and don't check it again.
Mine go down a few psi every few months, so not good to never check them.gn2 wrote:Alternatively, once the tyre is inflated to the correct pressure, leave it alone and don't check it again.
glencoeman
I would return to the garage and have a standard tyre valve fitted. I think angle valves were originally designed for agricultural tractors. The Honda Silverwing 600 uses an angled tyre valve with a bracket which goes over the valve to stop it moving - you must use the bracket if fitting angled tyre valves (same system as a Honda Gold Wing). There is no provision on the Forza for that kind of bracket.
dergav
- Color: grey
update for Forza owners information...to learn from my mistake...
One fact I had omitted to mention ( because I didnt think it relevant but now know it was!) was that after "turning" the angle valve I turned on and revved the engine while on centre stand for another reason...the angle valve facing my way apparently hits something as the wheel turns and that weakened the side of the valve resulting in it blowing.
My summary would be for Forza owners to avoid fitting an angle valve on their rear tyre and stick with the straight valve...and get one of those angle attachments for use when at the air pump...bit of a pain but safer.
iceman wrote:Mine go down a few psi every few months, so not good to never check them.gn2 wrote:Alternatively, once the tyre is inflated to the correct pressure, leave it alone and don't check it again.
Idiotic really...
Chief says better late with that part of the story than never.dergav wrote: after "turning" the angle valve I revved the engine while on the centre stand, the angle valve facing my way apparently hits something as the wheel turns and that weakened the side of the valve resulting in it blowing.
- mac&chief2.jpg (10.11 KiB) Viewed 3638 times
claudioggs
Hi,
Keep the original valve is a good idea (TR412 ??).
I added some external TPMS (tire pressure monitor system), and the rear one touched something, probably the caliper, so there are not to much gap.
May be you can install a very low profile valve stem like the attached ones.
Check also the the valve 65252-68 Motorcycle Bet, in Schrader catalog.
https://www.schraderinternational.com/~ ... 70113.ashx
Cheers
Cheers
claudioggs
glencoeman
Motorcycle tyre shops advise not to use angled tyre valves unless the wheel has a holding bracket like the Honda Silverwing 600 or Goldwing. Using the standard type valves will give no trouble.
