Removal of underseat storage compartment
dantheman
My coolant reservoir is leaking and I'm trying to get the storage compartment out so I can access it. I have removed the seat and 4 machine bolts from the bottom/front of the compartment. Also removed 2 screws up front on the sides. It doesn't seem any looser than it was before I started. Anybody know what the heck is holding that thing in there?
Re: Removal of underseat storage compartment
Welcome to the forums!
Perhaps a look at this "how to" thread will help: http://www.hondapcx.org/viewtopic.php?f=3&t=2630
OMG... make sure you put it back in
- IMG_1682.JPG (88.42 KiB) Viewed 9026 times
dantheman
Yikes, you guys are awesome.
I had the 2 screws out in the back wing but didn't gin up the nerve to "pry up gently". I'd also like to check the "suspension tutorial" to take the short cut, and report back on my results.
Thanks! I'll be donating to the cause.
A wee bit of help. Cheers
- image.jpg (26.3 KiB) Viewed 8996 times
dantheman
Operation went smoothly. No hassles. Great tutorial. Found the nipple for the hose that goes to the radiator was broken. New tank, including delivery, $12 at local Honda dealer. Also found the reason, and posted a caution on another thread dealing with coolant and reserve tanks.
Thanks again!
Thanks again!
Cool! Glad the how-tos were helpful.
- yak
- Minister of Magic
Dantheman, i had the same problem with the nipple breaking off. Now that i have the new coolant tank, i wanted to see if i needed to brace the tank to prevent movement. The tank seems to be firmly in place so i ended up not stuffing any padding around it. Do you think that the tank is actually moving enuf to break the nipple? Should i put in the padding?
dantheman
Minister, check my post on the thread "Coolant for PCX125" from Monday 8-17 (I'm not savvy enough to be able to send you that thread!) It explains what happened on mine and what my fix was. Make that simple visual check from below and if it looks good you're probably OK.
Nonetheless, a little padding probably wouldn't hurt anyway.
http://www.hondapcx.org/viewtopic.php?f ... it=coolantdantheman wrote:Minister, check my post on the thread "Coolant for PCX125" a little padding probably wouldn't hurt anyway.
open page you want to direct to, copy the browser text block address, paste into your post
dantheman
Thanks, homie. Copy/paste.....I may have done that before with email.
(Hey, gimme a break, man, I'm old)
So, in this thread, for example, I would copy the bold green title "Removal of underseat...." at the top, right?
(What do you expect from a guy who grew up in Chicago. La Grange. How 'bout you?)
- Year: 26 adv 160
No, copy the address that is in your browser at the utmost top of your screen. Ill shoot a pic...on my ipad its here:dantheman wrote:Thanks, homie. Copy/paste.....I may have done that before with email.
Bolingbrook, but I came here from Florida. I think windows 10 might piss me off, maybe I'm getting old too but fight it, you're only as old as your avatar online, no one cares.dantheman wrote:Thanks, homie. Copy/paste.....I may have done that before with email.
dantheman
Ohhhhhhhhhhhh. I get it.
Duh.....
(Thanks, boys!)
Duh.....
(Thanks, boys!)
White Noise that picture is of you! At first I thought not be then I remember one from a long while back when you first had your scoot delivered. So cheers to you too buddy and party on.WhiteNoise wrote:COOL!
Nah homie, that's my twin. Remember me saying twin? Yep! I'm one of two,...the better looking one
Reminds me of: "Two, two, two mints in one!" (God, that's an old!
an ad for __________?)
homie wrote:OMG... make sure you put it back in
Corona "light"?
Even with modern advances in chemistry how is that possible?
It's distilled water isn't it....?
homie wrote:White Noise that picture is of you! At first I thought not be then I remember one from a long while back when you first had your scoot delivered. So cheers to you too buddy and party on.WhiteNoise wrote:COOL!
Isn't whitenoise a burd?
