Hi everybody.
Due to absence of any proper Forza Owners manual I would need some advice.
I downloaded the manual which circulates on the web but which only has one Page about Instruments but does not give an explanation.
What actually tells me the top/middle Instrument? how to adjust the Clock and so on?
I appreciate your help here, Links to a full Handbook would be even more appreciated.
Regards, McGee
Need Help with Forza Instruments
- McGee
>> Marriage is a wonderful invention: then again, so is a bike repair kit. <<
- waspmike
Re: Need Help with Forza Instruments
Try this?
http://www.motorcycle.in.th/filemgmt/index.php?id=270
Seems to have lots on the instruments.
Press both buttons and hold till the time blinks
- waspmike
^ same as the Owners manual I posted.
- McGee
Thank you all
Thank you all for your Support.
unfortunately all my Googlework and your Links point to the same Manual.
Setting the Clock was a easy way and i figured that out by myselve.
But the little Digital Instrument in the middle give me some resistance ( the digits are so small and barely recognizable anyway )
I ma talking about the Average Fuel Consumtion Meter.
It attemts to give me only the average km with 1 ltr. gasoline and does not switch to other modes as in the handbook.
will late post some images of my Forza which I exchanged against a PXC after 3 years.
see you
see you
- waspmike
McGee,
As you are in Thailand it likely that yours is an Asian KO model or other Asia designation and not an E or U model. In which case it only has km/l and no other setting.
Have a look at the frame number and see what the country code is.
- McGee
KO Model. i like that but I would rather have a OK Model.
where to find the Frame No?
- McGee
Frame Number does not reveal Model Number.
having called my Dealer he says that Models sold here are called " NSS300ADTH"
- Frame-small.jpg (136.17 KiB) Viewed 2901 times
