What's missing here?
- Seph
I just saw this. What's this hole all about? Any ideas?
- Sorry for picture size, taken and posted on my phone.
- sketch-1438680180887~2.jpg (42.91 KiB) Viewed 2149 times
Seph
Re: What's missing here?
I thought that was the CBS brake fluid reservoir window thingy - very tricky to tell what level the fluid is really at as often it is full so no level mark visible when scooter upright).
- Seph
Is there a cover missing or is it like this on all the pcxs. Wasn't sure if it's popped off after my accident. Thanks
Seph
gmlawrence
I have a new PCX and noticed the same opening this weekend while looking for the dreaded rattle. Didn't find the rattle, but found the opening, so I assume this is how it was made.
- Seph
That's good to hear. I was convinced something was missing. Good luck with the rattle.gmlawrence wrote:I have a new PCX and noticed the same opening this weekend while looking for the dreaded rattle. Didn't find the rattle, but found the opening, so I assume this is how it was made.
Seph
- ScooteringAbout
That's normal on all PCXes. As iceman said, that is where you can check the level for the brake fluid for the rear / combined brake.
- Year: 26 adv 160
I have cut a small piece of 3M white carbon fiber vinyl to cover it… easily removed for inspection.....It looks weird just being open , even though I know it's an indicator window.
You should leave it open, out of sight = out of mind.
Its placed where it is for a reason, you see it every time you use the scooter.
If the level drops you'll notice it immediately.
Unless its covered up.
