drain bolt size
- Year: 26 adv 160
drain bolt size
What is the size of the threads on the crank\case drain bolt? M8, M10 etc....thanks. Just changed oil, a bit messy for my condo association, I'm getting a hold of Fumoto tech, mounting a valve as there is plenty of room and height....stay tuned...
Re: drain bolt size
Jge64 wrote:What is the size of the threads on the crank\case drain bolt? M8, M10 etc....thanks. Just changed oil, a bit messy for my condo association, I'm getting a hold of Fumoto tech, mounting a valve as there is plenty of room and height....stay tuned...
It'll be a bit exposed. Why not just get a vacuum oil pump?
- Year: 26 adv 160
Re: drain bolt size
Thanks..
investigating, the f107s Fumoto is shorter than the exhaust pipe clearance so it'll work, ...stay tuned...owned 4 fumoto's, they work great. Also had a few dipstick pumps on my marine engines, never felt they got it as much as draining when hot......
