Heygood people
I have a little niggle that has popped up on my 2011 PCX 125.... Yesterday I decided to do a service as it was almost due. Changed the oil, air filter and spark plug. I couldnt do that oil strainer as it just wouldnt come off and I didnt want to force it. Today I have noticed the throttle response has improved but after a couple of miles riding I noticed a slight misfire when I stopped at a set of lights. It may have misfired before but I cant be sure as I wasnt paying attention. The misfire is noticeable at stop or just taking off where it takes a fraction of a second longer to respond to throttle than ususl.. But this doesnt happen every time tho.... The misfire is noticeable at stop but once away I dont notice it...All the stuff came from a Honda dealership that sells everything for a service on fleabay as a kit so I doubt anything is out of spec.
Only hiccup I can think of is, its a brand change of oil (used to be castrol, now motul) and the other thing was the oil had leaked slightly in the delivery bag and there was a bit on the plastic bits of the air filter which I cleaned out. I couldnt notice any oil on the actually air filter element itself.... but perhaps there was some..
On a side note, I did take off the exhaust, sand down surface rust and repainted with very high temp oil but I doubt that was the issue. I have just added that on here just in case anyone thinks that may be a contibuting factor...
Any help would be appreciated....
Misfire help
Misfire help
2011 Honda PCX 125
- Color: metalic black
Re: Misfire help
Hi. Did you set the sparkplug gap correctly? Just because it is new does not mean it is correct for your bike. Get a set of feeler gauges and check it. Lack of air through a blocked filter would also cause poor ignition. The oil makes no odds whatsoever. The exhaust, unless you have damaged the gasket at the engine mount, it should be OK although a leaking gasket could also effect it.
Re: Misfire help
scudder wrote:Hi. Did you set the sparkplug gap correctly? Just because it is new does not mean it is correct for your bike. Get a set of feeler gauges and check it. Lack of air through a blocked filter would also cause poor ignition. The oil makes no odds whatsoever. The exhaust, unless you have damaged the gasket at the engine mount, it should be OK although a leaking gasket could also effect it.
Plug cap fimly back on?
Re: Misfire help
Thanks for the quick replies people.... The gasket seemed fine and I was very carefull getting the exhuast back on so I hope that isnt the case... It may well be the gap on the plug.... never having used a set of feeler guages (and not knowing how to use one) prevent me from doing so.... Any alternative ways to check or do I have no options on that one?
With the air filter... I did clean out the whole housing and everything so hopefully no issues from that... again it may be a case of oil in the filter itself (although cant be a huge amount.. or doesnt seem to be).
I have just checked the plug cap again and it seems to be on fine. I will find out in a bit when I get ready to ride. But I suspect it may be the gap on the plug....
And here I was doing the service for the first time without my friend (who is the bike expert) hoping all would be well... Wishful thinking on my part...
2011 Honda PCX 125
Re: Misfire help
Set of feeler blades/guage from any Halfords in UK will set you back £6 or 7. You just slip the blades in between the gap. (PCX gap is 0.8-0.9mm I believe). If the blade wont go in gently lift the bent tab with a flathead driver. Too slack, gentle tap on same with the handle of the driver. Guage should slip in and out with just a touch of resistance. NB every home mechanic should have a set of these so good investment.binje wrote:Thanks for the quick replies people.... The gasket seemed fine and I was very carefull getting the exhuast back on so I hope that isnt the case... It may well be the gap on the plug.... never having used a set of feeler guages (and not knowing how to use one) prevent me from doing so.... Any alternative ways to check or do I have no options on that one?
https://www.youtube.com/watch?v=q0cl_YrfjMc
That video uses a fancy tool to bend the earth.
Re: Misfire help
Thanks again for the reply scudder. Turns out it was the gap in the plug. Now thats sorted out it is purring like a kitten and running smooth.
Appreciate the help again guys :-)
2011 Honda PCX 125
