New Givi 323DT Windscreen
bubble
Easy Rider
Easy Rider
Post by bubble »
Well it was windscreen day today. This is what things looked like when I started:
1-Stock PCX - Copy.JPG (662.07 KiB) Viewed 2508 times
Then the GIVI went on:
2-PCX Pre-Cut - Copy.JPG (701.95 KiB) Viewed 2508 times
Here's the unwanted original profile:
3-Original Profile - Copy.JPG (459.85 KiB) Viewed 2508 times
To cut off 2.25 or 2.5 inches...
4-2.25 or 2.5in - Copy.JPG (442.02 KiB) Viewed 2508 times
Scratch protection:
5-Protection - Copy.JPG (401.28 KiB) Viewed 2508 times
The desired profile:
6-Desired Profile - Copy.JPG (675.55 KiB) Viewed 2508 times
The finished profile:
7-Finished Profile - Copy.JPG (526.78 KiB) Viewed 2508 times
Here's the finished windscreen:
8-Finished PCX - Copy.JPG (722.87 KiB) Viewed 2508 times
And here's the Silverwing windscreen next to the PCX:
9-Two Hondas - Copy.JPG (553.06 KiB) Viewed 2508 times
Hope I didn't screw this post up, & that I didn't violate any forum rules!
"Data control and I.B.M., science is mankind's brother." - J.A.
2013 PCX150, black. GIVI 323DT windscreen (cut down 2.5"), PowerbyPCX seat.
2002 Honda Silverwing, black, 35,000 miles. Oxford heated grips, Kuryakyn LED battery gauge, Comagination headlight & brake light modulators, RAM mounts, Givi trimmed windscreen, Givi E52 topbox, Formotion thermometer, Crampbuster throttle gizmo, Sumitomo car tire on rear.
2005 Honda Reflex-43,000 miles, sold.
tbln930
Year: 2013 PCX 150
Re: New Givi 323DT Windscreen
Post by tbln930 »
Looks great. How did you cut it and polish the edge?
SECoda/tbln930
bubble
Easy Rider
Easy Rider
Post by bubble »
tbln930 wrote:Looks great. How did you cut it and polish the edge?
Hi tbln930:
The cut was done with a jigsaw/metal cutting blade:
Cutting begins.JPG (224.17 KiB) Viewed 2500 times
Note the jigsaw platen is covered in duct tape to eliminate potential scratching.
The finished cut is honed with a palm sander, starting with 60 grit paper, then 120 grit, then finally 180 grit paper:
Palm Sander.JPG (244.11 KiB) Viewed 2500 times
Using a discriminating eye & a steady hand, you can achieve a stellar result. I'd say that if you paid ME to do this to YOUR windscreen, you'd most likely be tickled pink. The finished product looks virtually like a FACTORY FINISH.
I'd done two other Givi cut jobs, and all three look professional, IMO. Attention to detail with the jigsaw makes the rest of the job "all downhill".
bubble
tbln930
Year: 2013 PCX 150
Post by tbln930 »
Very good. I have all of the tools and tape, just not the fortitude yet. The high Givi on my Forza is a bit too high but I never really thought about trying to cut it.
SECoda/tbln930
bubble
Easy Rider
Easy Rider
Post by bubble »
tbln930 wrote:Very good. I have all of the tools and tape, just not the fortitude yet. The high Givi on my Forza is a bit too high but I never really thought about trying to cut it.
Be NOT afraid! Just be sure to use PAINTERS TAPE, make your cut so that your SHARPIE line is STILL VISIBLE when the cut is complete, and use a METAL CUTTING BLADE. In my case, the excess plastic re-melted back onto the windscreen as I was cutting. I had to actually break it apart, hence the break in the cut-off piece. Be sure to use a lot of pressure against the screen to avoid the BOUNCE EFFECT against the saw platen. Also, COVER the dash with a drop cloth, or you'll have plastic pieces in all the crevices! Take your time, and you just may surprise yourself. You CAN do this!
bubble
tbln930
Year: 2013 PCX 150
Post by tbln930 »
I have tons of the blue tape in different sizes. Yes - worried about that bounce and crack. Thanks for the confidence. :o
SECoda/tbln930
Looks great.
How were you sure not to cut it too short? I'd be concerned about that.
bubble
Easy Rider
Easy Rider
Post by bubble »
maddiedog wrote:Looks great.
Having done the Silverwing windscreen, and the Reflex screen before that, I had the confidence to do it properly, without the butterflies! I simply put the vertical tape on the screen, sit on the bike w/tape measure in hand. Holding the index finger at exactly the horizontal eye level on the windscreen, then measure that elevation. At that spot, I can either scootch up in the seat to see above any rain or condensation on the plastic (or get ventilation through the helmet vents), or hunch down to be protected from any rain or what have you. This proceedure works for me, and is a YMMV sort of thing. You may think the CUT LINE may be bothersome to look through while on the road, but I find that there are too many other things to focus on to even think about it.
Besides, it's only $165, lol. :lol: :lol: :lol:
bubble
