Dr pulley rollers
Need more speed
- Year: 61
Dr pulley rollers
Could someone please give me some advice on which is the best weight for dr pulley rollers for acceleration and top speed ?? Thanks in advance
Valiant
Re: Dr pulley rollers
Would honestly depend on your PCX model(125, 150?) and your body weight to be honest. 12-13g is recommended generally(I currently use 13g). The roller weight doesn't affect your top speed. Sliders and an aftermarket variator would.
- DAB
Anyone know the standard roller weight in the 2013 125 PCX. I have a manual but it only gives the dimensions.
Other rides
fast1075
Last night after work, I installed 13 gram sliders in my 2013 PCX150.
Why: Two reasons. First, I bought the bike used with 3000 miles on it. It has had a Judder/shudder taking off when cold, or after sitting a while until it warms up and I have ridden it a few miles. I wanted to take a peek at the CVT, and I figured I would have a new set of sliders for "just in case".
Second reason: Flat spot (sluggish) in the middle. It was obvious that the variator was going full closed too soon.
Teardown: Easy and straight forward. I found that two of the six stock rollers had some flat spotting. Everything else looked good. Belt in spec. Cleaned out the dust, installed the new sliders and put everything back together.
Results: No more Judder/Shudder. No more "flat spot" it has noticeably better take off. More amazingly, It gained some top end speed, about 2 MPH by the speedo, and it will cruise at 55 MPH with less throttle. I am extremely pleased with the outcome. I think the odd wear of two of the stock rollers was causing the problem with the Judder/Shudder.
The hardest part of the job was putting the lower panel back on.
The Fasterizer
fast1075 wrote:Last night after work, I installed 13 gram sliders in my 2013 PCX150.
Just enjoy your 2mph. It must feel fantastic.
fast1075
I put 200 more miles on it today. It is better than ever. Most of the time cruising along at 55 MPH. Got 98 MPG on the last fill up. That is as good as the mileage the Elite 110 got most of the time, but I rode it wide open everywhere.
Lovin' me some PCX 150.
The Fasterizer
Valiant
It's "only" 2 mph... until you get a ticketyou you wrote: Just enjoy your 2mph. It must feel fantastic.
- DAB
Ali,Alibally wrote:2011, 125cc and I have 13g sliders.
Where did you get your sliders from, unable to find a seller in the UK.
Other rides
Valiant
Did you check Amazon?
I got mine from there, but I don't know if the UK site has one.
- Alibally
I got mine off eBay. They came from scooter assassins in Thailand. They only took about a week to come and were about £21 if I remember rightly.DAB wrote:Ali,Alibally wrote:2011, 125cc and I have 13g sliders.
http://www.exportstrength.com/advanced_ ... h0&x=0&y=0
- Alibally
Webike have them as well. I've used them a few times and the service is great.
http://japan.webike.net/products/20564945.html
