Battery Tender Jr
SECoda
Honda Forza 300 &
Honda Forza 300 &
Battery Tender Jr
Post by SECoda »
I put one on the PCX direct to the battery posts but curious how anyone has attached it on the Forza.
TIA
SECoda
Honda Forza 300 &
Honda Forza 300 &
Re: Battery Tender Jr
Post by SECoda »
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
Four Battery Tender Jr's running now. :P
Just found the Deltran Battery tender plus at Costco today for 39.95
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
I mail ordered three of them (just the Jrs) for about $20 each and the fourth I got at Wal-Mart but it was $34 there. What a rip. o_O
SECoda wrote:I mail ordered three of them (just the Jrs) for about $20 each and the fourth I got at Wal-Mart but it was $34 there. What a rip. o_O
This one is a 12volt - 1.25 amps so maybe not good for scooter battery but still I thought it a decent price. Do we have 12 volt batteries in our PCX's?
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
SECoda wrote:Yes 12v
Thanks, then it's fine :D Went ahead and used a lead that came with it to hardwired to the battery. It promptly cycled through a short charge and then went into maintenance mode. I guess you can leave it on and forget about it until spring, don't really know as I haven't used one before. Interesting device, if you cross terminals it doesn't spark, If you cross connect it just gives a red light. I guess if it sensed I was putting it on a 6 volt battery it would have corrected me :lol: It's a battery charger for dummies!
It may think a 6v battery is a 12v is bad condition and start upping the volts/amps - not sure how that would work (unless it can make sense of the charge curve and suss it's not a 12v battery) or best to avoid using a 12v charger with 6v batteries!
Lesly56
Year: common123
Post by Lesly56 »
That is great dear and I am happy that you got your problem fixed. My Honda eu3000is generator is working great till the day I bought it. I have replaced it with my older one which was giving issues of supply since long time.
SteveP
Color: red
Post by SteveP »
SECoda wrote:I put one on the PCX direct to the battery posts but curious how anyone has attached it on the Forza.
TIA
At the bottom of the front end of the luggage compartment you will find a small panel that you can pop up with a small screwdriver (it has a plastic hinge so it doesn't come completely out). This exposes the positive terminal of the battery (covered by red protective cap). Move the cap out of the way and hook the positive clip of the Battery Tender to it, and the negative clip to a ground point...the bolt head of the seat hinge works fine. Have had one hooked there now since December.
tbln930
Year: 2013 PCX 150
Post by tbln930 »
Yep - old post I had it on by the end of the day back then. I have five on those BTs going. :P
SECoda/tbln930
CelticCross
Color: Gray
Post by CelticCross »
Yes - this was the first mod I made on my Forza.
