![Geek :geek:](./images/smilies/icon_e_geek.gif)
![Shocked o_O](./images/smilies/icon_eek.gif)
+1kcpcx wrote:I looked in the service manual and although I found the procedure, I can't see any recommended interval for the fuel filter replacement. I have to agree with gn2 until reeducated otherwise. Seems like the cost of replacing the fuel filter far outweighs any benefit. Here is why, according to my pea brain logic:
An automotive fuel filter lasts tens of thousands of miles, easily. This while filtering three or four times the amount of fuel per mile that your PCX is consuming, and therefore that the filter is filtering. If the fuel filter on my car can last a mere 30k miles (at a minimum), that is roughly 1,000 gallons of gasoline filtered. Assuming the filter on the PCX is rated to filter 1,000 gallons of gasoline, that means 90,000 miles as an approximate replacement interval. Even if you halved that, and assumed the PCX fuel filter could only filter 500 gallons of fuel, you're at roughly 45k miles on the odometer. I would bet good money that the factory PCX filter could easily filter through at least 500 gallons of gas at an absolute minimum.
Not surprising, therefore, that Honda doesn't worry about replacement too much. If a single PCX on the planet Earth goes 90k miles in it's life, I'd be shocked. Dropping $70 on a replacement filter would seem to me to be a very poor investment.
