2011-13 Reflector Mask.
Drifter
Year: 13
Color: red
Post by Drifter »
Some of us who are not fond of the front bottom reflectors have found ways to cover them up. This is what i did, i masked off the red panels and bottom of head light got some fusion satin black paint...here is the result. Also added the chrome trim to the front and rear fender as well.
I like the frontal look of the 15 better than the early scoots, quick easy and cheap!
Drifter
Year: 13
Color: red
Re: 2011-13 Reflector Mask.
Post by Drifter »
No comments........? OK then what do you think of the chrome fender trim....i like it!
pcx man
Post by pcx man »
I like the fender trim also. What did you use? Looks good. Did you get it at a car parts store?
ScooterMan
Post by ScooterMan »
I used black vinyl decal material cut to fit. But, I think if I did it again, I'd just mask it off, sand and paint. Would be much simpler. The decal is peeling as it can't hold the angle it's on. Not bad enough now to merit peeling it off and painting yet, but once it is, I'll do something about it. I care a bit less now since my 2013 now has my surf rack on it and is used primarily for trips to the beach to surf or skateboard.
2015 PCX 150 (White)[/color]
Clever, I like both Drifter :P I wish that Fushion paint was around years ago, it's such an easy way to "make that change!" Now, what I would like to see is the whole bike from the front.
Cheers to new ideas! ;) Thank you
