30,000 mile update......
scisor34
Post by scisor34 »
It's been 2yrs and 3 months since I purchased a 2013 PCX150 and am happy to report after 30,000 absolutely trouble free miles, I could not be more pleased with my purchase, still averaging 100 mpg. Michellin City Grips are a must when it comes time for new rubber. Just wanted to give an update about the incredible reliability of this scoot. I am curious as to how long it will go before a major failure. Hope everyone has a Merry Christmas!
SECoda
Honda Forza 300 &
Honda Forza 300 &
Re: 30,000 mile update......
Post by SECoda »
Wow. That's great news. Merry Christmas!
Can I ask what maintenance you actually did generally vs the schedule? Valve adjustments, etc.
Wow! 30K miles. We bought our first one (we have two) in August of 2012 and we have almost 11K miles on ours. You have a great advantage in that you live were it is almost always nice out. We would be riding all the time if we lived there too. We have talked and talked and talked about moving to Florida. However, there are several things that stop us. First and foremost is the added cost of everything down there. It is my understanding that there is no state income tax there. That would explain why everything is more expensive. I know that the individual doesn't control taxes, so i am not upset or anything like that. It is just that i am on a fixed income, so anything my wife and i do has to be calculated and discussed to the nth degree, and if we move, it will be the last move.
Meanwhile, keep on riding and let us know if the bike ever has any problems you feel we should know about.
scisor34
Post by scisor34 »
I change the oil every 3-4K miles. Just put on my third belt. Changed front disk and break pads at 27,000 miles because I let the break pads go too long. There is some wear on my stock variator that limits me to about 66 mph that I need to address. I know variators are a highly objectionable topic here, but I'm open to suggestions. I'm in SW Florida and am blessed that it's riding season year 'round. The terrain is flat as a pancake here so climbing hills is a non issue for me. I'm happy with the stock set up but if there's a legitimate upgrade in variators to get a bit more pep on take off as well as a few mph top speed, I'm all ears. Slinders with ??? variator. I've never inspected the valves, it runs and sounds perfect, why mess with it?
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
So oil, belts, brake pads was it? Same spark plug? No valve adjs?
scisor34
Post by scisor34 »
Changed the spark plug 3 times.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
Valve adjustments?
scisor34
Post by scisor34 »
I've never had the valves checked or adjusted.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
Excellent. Very low maintenance machines indeed.
Steph
Year: 2013 150cc
Color: Black PCX
Post by Steph »
I'm planning on holding off inspecting my valves until there is a cause to do so. Good to hear that scisor34's scoot is doing so well. :D
scisor34 wrote:I've never had the valves checked or adjusted.
That's my boy :D
Just had my cars first service. 20,000 miles and a oil and filter change and general inspection. £138.40.
Don't angst or fiddle.
GARETT0439
Post by GARETT0439 »
AWESOME!
How many miles are you getting out of tires?
I am at about 7k miles and replacing the rear. Front seems to have a lot of life left
yak
Minister of Magic
Minister of Magic
Post by yak »
Did you change the belt before problems appeared? If you experienced problems with the belt, what were they?
scisor34
Post by scisor34 »
I'm getting 8-10k miles on a rear tire and 13-15k on the front. I never had a belt failure or problem, just changed the belt when I'd lose 4-5 mph.
sendler2112
Year: 2013 PCX150
Post by sendler2112 »
You should do the valve adjustment. The first sign of trouble will be a tight valve after it is burned and will require a new head. Idid mine at 4,000 miles and will check them again sometime this winter since I now have 18,000 miles. My belt is also cracked so I have a new belt, Vario, and face and I will reuse my sliders. It's interesting how plastic can wear metal.
sendler2112 wrote:You should do the valve adjustment. The first sign of trouble will be a tight valve after it is burned and will require a new head. Idid mine at 4,000 miles and will check them again sometime this winter since I now have 18,000 miles. My belt is also cracked so I have a new belt, Vario, and face and I will reuse my sliders. It's interesting how plastic can wear metal.
and leather sharpen steel.
OriginalRocket
Post by OriginalRocket »
Wow! I'm right around 13,500. I have a 2011 125cc. I need to ride more!!!
haildamage
Post by haildamage »
the PCX is an extremely common vehicle here and the honda shop mechanics deal with a gazillion of them. they never check the valves on these here in japan unless there is some reason to think it needs to be done.
sendler2112
Year: 2013 PCX150
haildamage wrote:the PCX is an extremely common vehicle here and the honda shop mechanics deal with a gazillion of them. they never check the valves on these here in japan unless there is some reason to think it needs to be done.
They are remiss not to at least check them every 10,000 miles. Because Honda made the bodywork so hard to get in there. Otherwise it would be a twenty minute job since it has screw adjusters.
haildamage
Well they don't check them and the service manual doesn't give valve check intervals interestingly. It should be noted that 125cc bikes are a dime a dozen here and they have a ton of experience with small Honda engines. When the head mechanic at my local flagship Honda Dream motorcycle shop tells me we won't check them unless there are signs it needs to be done I trust his expertise and experience.
