Hi everyone riding to work today and at a set of lights noticed bike was idling faster than normal, bike was warmed up already. Blipped the throttle and it settled to normal and the idle stop then kicked in. It now will not idle normally at all. It spins the rear wheel quite fast when on the stand but does not seem to move the bike with me on it.
could this be a clutch issue or a throttle position issue? Bike seems fine at speed.
Tom
engine fast idle
Re: engine fast idle
Sounds like throttle sensor or cable tension issue.
- Alibally
I would check the throttle at the engine end first. I might be all seized up with salty crappy wet roads at the moment.
- Color: red
Bike has been fine this morning so I think it may just have been mud and salt round the cable. Its only about 1k off its next service so hopefully it will behave until then
