YSS Shocks adjustment
pcx125
Post by pcx125 »
Hi all,
I just upgraded and installed a few parts into my 2011 PCX125 and very happy with everything, but except a new YSS Shocks Z-SERIES OFFSET for Honda PCX Chrome 310mm was not as I was expecting. I am not sure is it because I was installed in-correct or do I have to make some adjustment on the shocks ? ... hope you can advice.
After installed the shock, I don't feel much different with the original shocks in term of riding/on the road or cornering, but a lots of people said there is a hug noticeable ...:)
Thanks
Reaper
Re: YSS Shocks adjustment
Post by Reaper »
You can adjust only the spring preload on these shocks, try to change settings on your taste.
pcx125
Post by pcx125 »
Hi Reaper
Can you quickly show me How to change the setting ? I bought this shocks from Xspeed and some how its not including instructions and tools .
Reaper
Post by Reaper »
I suppose there should be kind a YSS stick in the package, use it to rotate that big nut upside the spring. Rotating this nut you are compressing the spring, giving it more preload. More preload=stiffer spring, firmer ride. Your spring is made for a 70-90kgs rider weight, so if you are in 70-90kgs, it should work right , but if these shocks don't satisfy you at the end, you should just try another shocks..
I tried YSS G-Euro XL shocks, when I was in Thailand and took pcx for rent there. I noticed that rear wheel sticks to the ground much better than with the OE shocks. But overall the shocks felt a bit harsh for my taste.
pcx125
Post by pcx125 »
I will try that see what happen . Thanks
Reaper
Post by Reaper »
homey
Post by homey »
That storage box is a bit overwhelming, I bet its responsible for at least half of the mothman sightings.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
:lol: :lol: :lol:
I think it looks sharp and more visibility is good.
pcx125
Post by pcx125 »
Thanks for your information Reaper
With storage box :) just to ensure you can see me Homey ....
Thanks Secoda
Geez, I wish I could understand what they're saying in that video. That's a good one! Surprised to see how easy it is to adjust those YSS shocks. My Piaggio MP3 was a bit_ _ to adjust, even with the provided tool.
Thanks for pointing us to the video Reaper ;)
