Rear Wheel noise
jojo87
Year: 2015 Honda MSX
Rear Wheel noise
Post by jojo87 »
Anyone know what's causing this noise,
if it's fine then no problem,
but would like to know what's actually causing it,
especially as the Wheel slows down,
sounds weird.
Re: Rear Wheel noise
It could simply be a bit of resistance on the brake drum, but my guess is that it is because you are spinning the wheel backwards. Does it sound the same when you spin it forward?
mrags89
Post by mrags89 »
If you're referring to the whistling sound, mine does that when I back it up also. No idea why it makes that sound...
Inoplanetyanin
Year: 2018
Color: WHITE
Post by Inoplanetyanin »
Wheel bearing? Final drive lacks sufficient oil? Clutch bearing needs replacement or regrease?
Its being caused by you spinning it backwards.
Don't spin it backwards and it won't make that noise.
Lagerhead
Post by Lagerhead »
I've had a similar noise in both of our 2013 PCX's. Both times it was the inner driven face bearing. Honda part# 91002-GA7-701
Item # 19 in the picture. although if your doing it yourself it's much easier to just replace the entire assembly. (Item #8.)
pcx driven face.JPG (70.01 KiB) Viewed 15446 times
mikelx5
Post by mikelx5 »
yep thats just what i was gonna say imnes does the same way easier for the whole thing
DISOBEDIENCE CREW
dem0nk1d
Post by dem0nk1d »
what happened to the video? i too am experiencing a loud dragging sound when rotating the rear wheel by hand
Hmm..yeah it says "this video does not exist"
Wha happened jojo? Dang! I missed it! :|
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
That entire assembly Driven Face #8 is only $24 US. I may just pick one up as a spare.
I agree. Hopefully this item is not on backorder any more, like it was when ours went out. It seems that more and more of the 2013s are showing up with this problem. I am guessing that there were a batch of bad or improperly packed bearing assemblies that went into production bikes. Just buy one of those replacement parts and take care of the problem yourself, before it fails while you are riding.
Mel46 wrote:I agree. Hopefully this item is not on backorder any more, like it was when ours went out. It seems that more and more of the 2013s are showing up with this problem. I am guessing that there were a batch of bad or improperly packed bearing assemblies that went into production bikes. Just buy one of those replacement parts and take care of the problem yourself, before it fails while you are riding.
Any reports of next gen 14's or 15's having this bearing issue?
jojo87
Post by jojo87 »
Sorry guys, deleted it from mu YouTube (as it was my business one) and was told it was just due to be turned backwards, so deleted it.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
I ordered it and they shipped it within 4 hours. Must be in stock. ;)
http://www.powershondaparts.com/
dem0nk1d
Post by dem0nk1d »
http://youtu.be/RCgGrpH_Qqs
Here's a quick upload of the noise I'm getting.. I don't think it's the torque driver..
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
Wow. That is significant.
magic_mike
Post by magic_mike »
I heard it in person
told him there was a bad noise
sounds like a bearing to me, grindy when spinning the wheel either direction
I thought the gear oil has no oil, or bearing in the gears is going bad was my guess
dem0nk1d
Post by dem0nk1d »
magic_mike wrote:I heard it in person
im driving the car in the morning. i think it's the torque driver needs new grease. already tore everything apart and regreased everything. now i just need time to clean out the variator... time to order new rollers too while i'm at it.
jojo87
Post by jojo87 »
I think mine was similar to that but not as bad, i'll try it again when it stops raining.
Wow, could hardly believe the noise coming from that wheel! Reminds me of the phrase from Aliens 'you've blown the trans-axle - grinding metal on metal'.
