Need help badly
MagicSeaweed
Need help badly
Post by MagicSeaweed »
Ok guys I've screwed the pooch,
Went to change spark plug all going well then just as I had it tight enough go to remove the tool and it all breaks off,
What do I do now, can I attempt to cut the sides and remove with a flat head? Or do I need to bite the bullet and take it to a dealer to take it apart and remove?
Any help would be greatly appreciated
dasshreddar
Year: forzaruckuspcx
Re: Need help badly
Post by dasshreddar »
I would first try a dremel tool cut off wheel and make a slot in the stub(for a flat head screwdriver), and or keep chiseling it out... of course don't go into the threads.
keep the threads lubed!
MagicSeaweed
Re: Need help badly
Got the ceramic out so there is no risk of it falling into engine now, time to work out a removal tool to use?
MagicSeaweed
Re: Need help badly
Ok going to have a go using this guide as it seems to have worked for a few people,
http://adrielmichaud.com/mr-fixit/how-t ... park-plug/
Re: Need help badly
MagicSeaweed wrote:Ok guys I've screwed the pooch,
Did you do this screwing it in or out?
MagicSeaweed
Re: Need help badly
In sadly :(
pcx man
Re: Need help badly
Post by pcx man »
Unless you cross threaded the plug, it should back out very easy. If the plug is sticking out a bit use what ever you have to grip the edge. Have you tried lubing it with WD-40? It may back out just using your finger.
Mgalutia88
Year: 2013 PCX 150
Re: Need help badly
Post by Mgalutia88 »
Try one of the stripped Philips head screw easy outs.
Alibally
Re: Need help badly
Post by Alibally »
I see your in Southampton. Pop along here. It's open today.
http://www.machinemart.co.uk/pages/stor ... outhampton
Alibally
Re: Need help badly
Post by Alibally »
You will need one of these.
They work fine. There is a reverse thread on them. You turn them anticlockwise to screw into the plug so it should come out as long as it's not been cross threaded. I presume the ceramic is out the middle so there is the hole in the middle?
http://www.machinemart.co.uk/shop/produ ... wrench-set
MagicSeaweed
Re: Need help badly
Yes got ceramic out, that's great, actually at Thorpe park today XD, but will get on it tomorrow and update progress
Re: Need help badly
MagicSeaweed wrote:Yes got ceramic out, that's great, actually at Thorpe park today XD, but will get on it tomorrow and update progress
Wonder if your a member of the rccgb? http://www.rccgb.co.uk/ (just on the off-chance)
MagicSeaweed
Re: Need help badly
Hi guys,
Update that I solved the problem!
I decided to see if I could get a flat head down the hole and gently twist it out....
image (5).jpeg (33.14 KiB) Viewed 4930 times
Turns out I could!
Thanks for all the help everyone!
P.s Not part of the Roller-coaster society but looks fun!
Alibally
Re: Need help badly
Post by Alibally »
Well done. Cheaper than a remover set as well.
Re: Need help badly
Well done. Mustn't have taken too much torque to get it out. So presumably the same to get it in
Bit worrying if the plugs are this weak
DAB
Re: Need help badly
Post by DAB »
In 40 years of motorcycling this is only the second time I have heard of this happening. The first one was 2 months ago on a VFR 750.
Other rides
MagicSeaweed
Re: Need help badly
I thought the same about the strength of the plugs as when it broke it was tightened to spec in the owners manual, thus I didn't consider straight away to just try a flat head, but unscrewing was almost frightingly easy aha XD
