Tools:
MIG Welder
Angle Grinder
Cut off wheel
Flapping Disc
Blue tape
Safety Glasses
Decided I'll make the cut at the end cap behind the weld, and start from that weld line to 7"
Sharpied in the 7" mark
All taped up for guides
And so it begins!
I had to section out the rear of the exhaust because the inside tubes go into the end baffle
Baffle is spot welded into the out exhaust shielding, and i thought it was going to be easy
Has to finish the rest of the pipe off with a sawzall this basically released the rear section of the exhaust and reviled the CAT
Mayhem!
Cat materiel is pressed into the inner tube, the main header tube i guess you could say. I used a number of drill bits to loosen this stuff up.
Perfectly gutted!
Main plastic shielding mount has to go!
Take your cutoff wheel and get close ass possible then work at the rest of the metal with the flapping disc
Try to get the cap matted up with the other half as perfect as possible this will make welding things back together much easier
I then went back over the welds and grinded them down and tried as best as possible to smooth them into the pipe
Mounted and ready to go!
So the main question is how does it sound? If you imagine or have ever been to a destruction derby, it's like that! I'll try to post a video later, but even the audio can't compare to the real thing. I'll be testing some other designs for the internal baffling situation to make it A LOT more quite! More or less going with that perforated steel. We will see how long it takes for me to get rolled by the cops. I have feeling it will be soon.
