Performance parts
pcx125
Re: Performance parts
Many many thanks guys
- Alibally
I got a set of 10g Dr pulley sliders to try. It doesn't seem to make a lot of difference from the 13g ones I had in except for revving hard now when you accelerate. I'll give them a go for a while but will probably put the heavier ones back in. I am not wanting run about with the thing screaming its head off all the time. It's not good for the engine or the fuel consumption for that matter.
pcx125
Thanks for your updated. I already ordered 10g Dr pulley sliders and it will be arrive soon
)) I may not install it the
I may need more infor about malossi multivar 2000 with the 10.5 gr weights now
- Alibally
If you've ordered them then give them a go, you might think they are fine. It only takes 20-30 mins to fit them so what have you to lose.
pcx125
I also still looking for some tools to remove variator as well
Thanks
Thanks
- Alibally
I made one. Looks like this.
- ImageUploadedByTapatalkHD1399564183.216037.jpg (90.8 KiB) Viewed 4363 times
pcx125
thanks Alibally
It wasn't worth the effort for me to build a tool, especially when a premade one is only $20. Here's the one I use to get off the clutch or variator on any scooter I'm working on: http://www.amazon.com/gp/product/B000HS4NA8
Mgalutia88
- Year: 2013 PCX 150
Malossi multi var is good but daytona variator provides great acceleration and a higher top speed along with it. I think it's around 3-4kph higher top speed.
- Alibally
Mine cost me nothing as I had the raw materials lying around the garage.maddiedog wrote:It wasn't worth the effort for me to build a tool, especially when a premade one is only $20. Here's the one I use to get off the clutch or variator on any scooter I'm working on: http://www.amazon.com/gp/product/B000HS4NA8
The bought tools are stronger looking though but the home made on works fine.
- 6ftMach1Girl
Where did you get your Daytona variator?Mgalutia88 wrote:Malossi multi var is good but daytona variator provides great acceleration and a higher top speed along with it. I think it's around 3-4kph higher top speed.
pcx125
No, I used Malossi multi variator with 10.5 grams rollers and very happy so far .
