leo vince exhaust
leo vince exhaust
so i ran my exhaust for a while (3000 miles or so) got to the piont that i love the exhaust, this was without silencer. so i have a few friends with sensitive ear, so i installed the silencer. it sounds terrable like a really bad rice burner car exhaust with an exhaust leak. just figured i would let you guys know for anybody looking into it.
it is also noticably more restrictive
DISOBEDIENCE CREW
Re: leo vince exhaust
im running the stock exhaust bored out with a 22mm drill bit. Also i went about 6" into the pipe. Sounds really good, and the pod filter really increased throttle response and power. I think the whole exhaust thing is hype.
- dasshreddar
- Year: forzaruckuspcx
Any pics of this ? I would cut the exhaust off at the header drill through the cat and reweld... to really open it updem0nk1d wrote:im running the stock exhaust bored out with a 22mm drill bit. Also i went about 6" into the pipe. Sounds really good, and the pod filter really increased throttle response and power. I think the whole exhaust thing is hype.
Mightyhonu
Demon if you have pics and more information that would be great.
its not hype its just not too noticeable in a lot of cases but it took me from 55 on an uphill to 60 with very similar conditions (weather, traffic, wind) also higher top speed from 70 to 74 on flats. so not huge numbers but its way smoother.
DISOBEDIENCE CREW
mikelx5 wrote:its not hype its just not too noticeable in a lot of cases but it took me from 55 on an uphill to 60 with very similar conditions (weather, traffic, wind) also higher top speed from 70 to 74 on flats. so not huge numbers but its way smoother.
Sorry i mean the whole over priced exhaust do work, increase flow and make the engine happy, happy, happy! But for the price they want it's almost not worth it. With our stock exhaust i was able to open it up a little more, and i did notice a little more top-end.
However this is what i did. Took a 22mm drill bit and drove it directly into the exhaust exit tube. I put the drill as far as it would go and i think it went through two baffles and some kind of funky pipe inside the stock exhaust. Here is a picture below but doesn't do justice. When it gets light tomorrow i can take some better pictures...
dem0nk1d wrote:
I took a 22mm drill bit and drove it directly into the exhaust exit tube. I put the drill as far as it would go and i think it went through two baffles and some kind of funky pipe inside the stock exhaust. Here is a picture below but doesn't do justice. When it gets light tomorrow i can take some better pictures...
How did that change the exhaust noise levels? I would like to try something similar as long as it did not make it obnoxious noisy.
(We already have enough Harley's around here to take care of that)
Current - 2015 Honda CBR650F
I haven't really rode in the rain yet with out the airbox. However the pod filter is right behind this rubber flap and rear wheel. Only way to find out is when it rains next. I might just build a radiator hose intake and try to move it up to the front of the seat area. This way it would give me more insurance that it would stay drier when it rains.mikelx5 wrote:do you have any problem with rain without the the airbox
- dasshreddar
rain proof... and I also have one of those k&n dirt socks over the whole peanut butter jar
- airpod.jpg (197.74 KiB) Viewed 15631 times
It just needs a wasp in it
Or Two. The honeycomb board & filter.
Das, Plastic Jar from Jiff all natural PB? Bestest!
- ScooterCommuter
After running my Leo Vince Corsa exhaust for a while, I replaced the stock exhaust anticipating state inspection. The performance of the Pcx150 improved immediately. Stock is so much faster despite the weight of the factory exhaust. Leo Vince looks nice, but I will take performance over looks. Just my experience after about a thousand miles with the aftermarket exhaust. No offence to those who've had a better experience.
current: Honda Pcx 150
previous: Honda Reflex 250, Suzuki Gs500, Yamaha Vino 70 mod
'Never Ride Faster Than Your Angel Can Fly'
well to add to this DO NOT use the leo if you run on the highway for extended periods of time. first the slip seal went bad so i had it welded, then a weld broke, then all the sudden the bolt stripped and pipe sheared so if its just around town and you wanna make noise(my original plan) then go ahead but it is not high enough quality to hold up to the heat and scootercommuter i do see what you say on the bottom i feel like i lost some top end though so i think it just moved the powerband lower.
so demon does it hurt take off at all or just louder all around and thats all
DISOBEDIENCE CREW
I did something similar but instead drilled 3 holes in the back of the can. The metal is relatively thin so it was pretty easy.dem0nk1d wrote:mikelx5 wrote:its not hype its just not too noticeable in a lot of cases but it took me from 55 on an uphill to 60 with very similar conditions (weather, traffic, wind) also higher top speed from 70 to 74 on flats. so not huge numbers but its way smoother.
The performance gain was small, but the engine definitely breathes easier and sounds better.
If i could power my go pro, i'd so a video around the block for take of speeds. But i think boring it out to 22m was the magic number. Feels peppy all around. Now the bigger tires i went to raped performance all over the board.
Off the line is about the same as stock.mikelx5 wrote:hows your off the line grunt
As Demonkid said, the performance gain is in the mid to upper range. Slightly better acceleration from 50Mph to Top speed and a better exhaust note.
Don't expect to get miracles here. This is just a small incremental improvement.
The mod is fairly cheap or free if you already have drill bits! I highly recommend it! I'd like to gut mine and remove the "MEOW" inside of it. =) EPA what?Slickvic wrote:Off the line is about the same as stock.mikelx5 wrote:hows your off the line grunt
