Gerbing 12 volt port
ptmcd1
Post by ptmcd1 »
i mounted this port in the storage box door. with my Gerbing heat controler connected in series with the 12 volt power cable which i installed through the back of the box, i have heat control to heated clothing, in this case i use Gerbing G-3 heated gloves for my old hands,heat is applyed to the full hand portion of the glove not just the palm. i just connect the glove power cord to the port on the box door. i have tried hot grips on all my rides but hot grips do not even come close to the performance of heated gloves. when my scoot is not in use i connect my battery tender to the port on the box door. be safe.
paul.
http://i1077.photobucket.com/albums/w48 ... G_0353.jpg
http://i1077.photobucket.com/albums/w48 ... G_0351.jpg
http://i1077.photobucket.com/albums/w48 ... G_0038.jpg
Re: Gerbing 12 volt port
Nice setup. How much do heated gloves like that cost? I'd imagine heated gloves would work much better than heated grips.
ptmcd1
Post by ptmcd1 »
my set up cost about $200.00 complete. Gerbings G3 gloves, soft and plyable, can be worn as normal street gloves, they are not bulky, or plug in to the temp control and dial in your temp. i have a single temp control , however dual controls are avaiable for jacket/pants/foot warmer on one port and gloves for the other. my single control is mobile so i can use the gloves and control on all four of my bikes/scooters. www.gerbing.com for more info
maddie, there is a stocking dealer north of you in jasper ga, r&r trikes.
Paul.
Cumming Ga.
