Got myself some LED running lights
I used these on my PCX and loved the extra visual presence it gives - definitely a good investment for our ever increasingly myopic drivers. Have now installed a set on my Forza.
Made by Durite
Here's a sample with/without
Made by Durite
- image.jpg (38.5 KiB) Viewed 9765 times
- image.jpg (176.5 KiB) Viewed 9765 times
- image.jpg (125.29 KiB) Viewed 9765 times
Re: Got myself some LED running lights
They are switched separately and wired to come on with the ignition
- image.jpg (220.24 KiB) Viewed 9723 times
- image.jpg (239.31 KiB) Viewed 9723 times
MrSuperchicken1
What is all that "covering" you have there? Some kind of winter wind blocker?
- willajabir
Skuder skirt. Yep for wind and freezing temps.
Larry
2014 NSS300E born on 12/11/13
May the Forza be with you
- Hammy
- Year: 2014 Forza 300
How did you mount your lights? Is there a frame mount under there?
Hammy
IBA #542
2014 Honda NC700XD
2014 Honda Forza 300
IBA #542
2014 Honda NC700XD
- Year: 26 adv 160
I mounted strip leds on the fender. Totally reversible, with vhb tape and ran a quick disconnect harness to the power adaptor wires which is ign switched on. Mounted for additional lights for oncoming drivers to see not to supply more driving light. Total cost was under $20. Bern working fine for over a year now.
davenowherejones
The positioning of the lights looks like they would make the turn signals difficult to see for oncoming traffic.Hammy wrote:How did you mount your lights? Is there a frame mount under there?
Personally I would try to put them much lower.
[quote="Jge64"]I mounted strip leds on the fender. Totally reversible, with vhb tape and ran a quick disconnect harness to the power adaptor wires which is ign switched on. Mounted for additional lights for oncoming drivers to see not to supply more driving light. Total cost was under $20. Bern working fine for over a year now.
I like the mounting position, as it's out of driver's FOV unless doing some really strange maneuvers.
Some of my lights.
