This normal?
TC3
This normal?
Post by TC3 »
After giving the scoot a bit of a clean I noticed this. Should the metal look like that on a 5 month old bike? Any ideas what to do about it as not sure it is a warrenty claim?
antwhiting
Re: This normal?
Post by antwhiting »
yep, if you ride it over the winter months the metal components take a beating. Mine is only 3 months old and its looking the same.
Could be worth a call to your local dealer to see what they say?
2011 HONDA PCX 125
TC3
Re: This normal?
Post by TC3 »
Hm did not ride in salt conditions which is why I am surprised.
antwhiting
Re: This normal?
in that case, i have no idea.
I live on the coast so that would explain why mine has deteriorated so quickly.
2011 HONDA PCX 125
Re: This normal?
It's perfectly normal and it isn't a warranty claim because it's function is not impaired.
If you don't clean it at all it ends up looking like it's been sand cast.
So there are three options:
1: Strip it down polish and lacquer it (pain in the arse, takes ages and will need repeating)
2: Strip it down paint and lacquer it (pain in the arse, takes ages and will need repeating)
3: Leave it alone (no user input required)
I go with option 3
Re: This normal?
Normal, mine looks the same. She'll age and get less pretty, you can't do anything but enjoy the ride and not worry about it. ;)
edscoot
Re: This normal?
Post by edscoot »
I give everything a quick wipe over with wd40 or ACF50 after cleaning just to help stop the alloy oxidising. Your picture looks fine to me - nothing to worry about, just give it a squirt with wd40 if you want it really clean.
TC3
Re: This normal?
Post by TC3 »
Wd40 made it look worse as now you can clearly see the patches of shiney metal underneath the dull matt outer coating. Just a bit surprised how it is looking scurffy so quickly. Oh well just have to live with it and at least it is outta sight. Option 3 it is then!
Re: This normal?
Careful where you squirt that WD40, there's things inside there which you don't want to get lubricated...
trigg123
Re: This normal?
Post by trigg123 »
wonder wheels is the stuff to clean that alloy,bring it up a treat but obv wont change the finish
be carefull applying it :o
TC3
Re: This normal?
Post by TC3 »
GN2 thanks for the warning. Only sprayed a lil on the outer casing so none got inside.
TC3
Re: This normal?
Post by TC3 »
Would never use wondrr wheels again. Was ok on the mini alloy wheels but it really messed up the finish on my Mondeo wheels years back.
Esdain
Re: This normal?
Post by Esdain »
wd40 that near your rear brake?
TC3
Re: This normal?
Post by TC3 »
Near rear brake but I am not crazy enough to spray wd40 where it should not go :-)
TC3
Re: This normal?
Post by TC3 »
So a qjick update. Dealer took pics and submitted to Honda who say it is not a painted part and is not covered as this is normal wear and tear.
Off course some already knew that but here it is from the horses mouth
Re: This normal?
You could carefully mask the area around it off and spraypaint it with some good paint.
TC3
Re: This normal?
Post by TC3 »
May do so if it gets much worse. Might then apply clear protective film on that bit I spray paint.
Fiah
Re: This normal?
Post by Fiah »
So I guess this is how my PCX looks like under the inch thick layer of caked on dirt?
TC3
Re: This normal?
Post by TC3 »
Yep...should not have cleaned mine :-)
