Hi Visibiliy and being seen!!
- dustin91
Re: Hi Visibiliy and being seen!!
Beautiful job! I just put some lengths of 2" thick red 3M reflective tape on mine (something tells me I've already stated as such on this thread), but it just looks like some dashes in the reflection. That outline work is gorgeous!
Thanks George! The tape I ordered was 1/2 inch so I had to trim it half and half again so it was very narrow. Had I known 1/8 inch was the best width to go around curves I'd have gotten that to start with. Really surprised how such narrow tape reflects so brightly.
Yeah thanks Dustin. Your post is the reason I decided to try the tape before the LED lights. In the daylight you can barely see the black tape. I wanted to use even more but thought about how it would just be that much more to remove if the need arose. I'm gonna live with this for a while and see how it holds up to the elements.
- ScooterKim
Mel and DJCat are right. use all the hi vis stuff you can, but in the end, ride like you are invisible.
@ScooterKim: yep! On my white Can Am Spyder I'm a great big visible freak of nature, but this awesomely fun little PCX has taught me plenty about the folks we share the road with. Already adjusting my riding habits.
I added a little more tape to my bike tonight.
- image.jpg (33.78 KiB) Viewed 3955 times
- image.jpg (76.38 KiB) Viewed 3955 times
- image.jpg (80.01 KiB) Viewed 3955 times
djcat
- Year: 2012
Nice job with the decals, certainly helps. However reflective stickers only help with light hitting them directly, if you want to mitigate situations like the one you described, the only way to go is either active light or high viz.
I will stick some battery powered bicycle LEDs to my mirror stems, research has shown that people have issues in judging the distance to a single source of light. Giving them more than one point of reference helps them to judge distances better.
Whenever I think its of benefit and will not cause an accident (e.g. by glaring oncoming traffic), I do switch on the high beams. Works wonders when filtering (filtering/lane splitting may be illegal where you are though).
MrSuperchicken1
Where, may I ask, did you get this tape from?pcxjojo wrote:After several hours of trimming, crouching, and a bit of swearing. I got the reflective tape on my bike! Don't think I'm going with lights cause I'm just too lazy to install them.
Thanks
- haildamage
pics?!?ben wrote:I covered my PCX in LEDs about 3 months ago to make me more visible ready for winter.
Might have slightly overdone it to be honest but there's no way someone can say they ''didn't see me'', well worth doing!
I'll post some photos when i get round to it...
as for horn upgrades, i recommend the Screaming Banshee as a step up from the Stebel! have one on my PCX and it is awesome!
it give you the option of using the stock horn for short friendly beeps or you can let the banshee scream by holding the horn button for more than a quarter second. it also flashes the high beam in banshee mode.
http://screaming-banshee.com/
Got the tape from a company called Streetglo on the Internet. I bought 1/2 inch but to get it to go smoothly around the curves I trimmed it down to 1/8 inch. They sell it in that width so I should have just bought it that width to start with.
ScottDR
Hi Jojo.pcxjojo wrote:Yeah thanks Dustin. Your post is the reason I decided to try the tape before the LED lights. In the daylight you can barely see the black tape. I wanted to use even more but thought about how it would just be that much more to remove if the need arose. I'm gonna live with this for a while and see how it holds up to the elements.
How has the black tape held up?
Thanks!
2013 Black PCX 150
Mods/accessories:
Previously owned:
1975 Honda CB125
1986 Kawasaki Ninja 250r
Beautiful, I have similar discreet reflective tape all over my PCX but unfortunately it proves to be nearly worthless in anything but a camera lens. Take a ride out in front of your cars owns headlamps tonight with your camera filming from the dash of your car through the windshield. Just don't want you to be over confident that traffic see that at night... or at all sadly.
ScottDR
Darn. I assumed so but truly appreciate your honesty!
I put SOLAS tape around the flange/rim of my Honda trunk. That stuff is one of the brightest out there. Will add some of the same black reflective stuff as you did on the body lines (I will copy yours) as i went ahead and ordered some with high visibility helmet stickers from streetglo.
Cheers and thanks for the super fast reply!
2013 Black PCX 150
Mods/accessories:
Previously owned:
1975 Honda CB125
- GatorGreg
Yes! Here are a couple of my vids:pcxjojo wrote:Hi all! Has anyone added LED lighting to their PCX?
Given that pcxjojo hasn't logged in since late 2013 I think its highly unlikely you're ever going to find out.ScottDR wrote:How has the black tape held up?
- Ishkabibble
Sometimes, it actually is beneficial to not be seen.
Not on a scooter or motorcycle, but in most cases...
JoJo's alive and well over at Grom Chat under the user name MXS87. She's has 199 posts and asking questions like why doesn't the Grom have a gear light indicator? That girl was always fun, I miss her.gn2 wrote:Given that pcxjojo hasn't logged in since late 2013 I think its highly unlikely you're ever going to find out.ScottDR wrote:How has the black tape held up?
I hope she finally learns basic manual transmission
http://www.hondagrom.net/forums/7-grom- ... art-5.html
yes its pretty scary how easy it is to find someone on the net
homie wrote:JoJo's alive and well over at Grom Chat under the user name MXS87. She's has 199 posts and asking questions like why doesn't the Grom have a gear light indicator? That girl was always fun, I miss her.gn2 wrote:Given that pcxjojo hasn't logged in since late 2013 I think its highly unlikely you're ever going to find out.ScottDR wrote:How has the black tape held up?
I hope she finally learns basic manual transmission![]()
yes its pretty scary how easy it is to find someone on the netthat took 30 seconds
Stalker
Yes that's true I did just stalk her. When people drop off hopefully they're enjoying a different bike or sold the PCX or worse... why there is no crash fatality list.you you wrote:homie wrote:JoJo's alive and well over at Grom Chat under the user name MXS87. She's has 199 posts and asking questions like why doesn't the Grom have a gear light indicator? That girl was always fun, I miss her.gn2 wrote: Given that pcxjojo hasn't logged in since late 2013 I think its highly unlikely you're ever going to find out.
Stalker
You have to admit JoJo was interesting and you feel better she's OK. Unique in as much as she worked on her own scoot doing maintenance and Mods many guys wouldn't attempt. Made lots cool video's showing her life style on the streets from her PCX in the UK. She road hard, crashed big, and got up went back out after injuries to take on clutch bikes.
She met her match with clutches being born of the twist-n-go generation she over thought manual gears. Remember how we all tried to teach her
The intolerable rattle she got with the insurance companies new PCX just pissed her off and she bailed on us. Yep JoJo's alright and I hope all the cats on her street step it up or she might run them over
- mac2.jpg (8.47 KiB) Viewed 3732 times
