"Mud flaps" falling off
Gingivitis Khan
Post by Gingivitis Khan »
Today I noticed a piece of rubber sticking out from under the body panel just above the rear tire. It looks like a shield to keep dirt from getting on the engine. The one on the left side is hanging, and the one on the right side is gone. Time for a trip to the dealer. Just a heads-up for other Forza owners.
Left side:
2042 by ScubaDude1960, on Flickr
Right side:
2044 by ScubaDude1960, on Flickr
And a photo I took the day I got the bike:
1961-c by ScubaDude1960, on Flickr
Re: "Mud flaps" falling off
I found one of them undone when I got mine but I just connected it back on.
At least the PCX doesn't fall apart within minutes :D
Ronin Jim
Post by Ronin Jim »
I check the bike every day and so far have not noticed this problem.
Jim
you you wrote:At least the PCX doesn't fall apart within minutes :D
No, it takes hours rather than minutes for the crankcases to self-destruct.
Gingivitis Khan
gn2 wrote:I found one of them undone when I got mine but I just connected it back on.
I can't figure out where to connect the other end. The only hole I can find is in a tab on the metal frame up under the plastic bodywork, but it's too big.
:lol: Both of you make me :lol: thanks, I needed that ;)
MORON
Post by MORON »
actually my 2013 PCX 150 did have loose parts....some of the plastic was loose and I only discovered so because i did all my own servicing. some of the 6mm's and the body panel screws....but you know built in japan but assembled here so sloppiness abounds....
Thought the PCX was manufactured and assembled in Thailand?
DAB
Post by DAB »
gn2 wrote:Thought the PCX was manufactured and assembled in Thailand?
Dealer told me that mine was made in Italy?
Other rides
You'll be able to tell from your VIN
