Honda Forza Specifications
2014 Honda Forza Specifications (mirrored here from Honda's Website)
ENGINE
Engine Type 279cc liquid-cooled single cylinder four-stroke
Bore And Stroke 72.0mm x 68.6mm
Compression Ratio 10.5:1
Induction PGM-FI with automatic enrichment
Ignition Full transistorized
Valve Train SOHC; four-valve
HP = 24.5 @ 8200rpm
Tq = 19 ft/lbs @ 6000rpm
DRIVE TRAIN
Transmission Honda V-Matic belt-converter continuously variable automatic transmission
CHASSIS / SUSPENSION / BRAKES
Front Suspension 35mm telescopic fork; 3.7 inches travel
Rear Suspension Twin shock; 3.8 inches travel
Front Brake Single 256mm disc with twin-piston caliper with CBS (third front brake piston is activated upon application of rear brake)
Rear Brake Single 240mm disc with single-piston caliper with CBS (one front brake piston is activated upon application of rear brake)
Front Tire 120/70-14
Rear Tire 140/70-13
DIMENSIONS
Rake 27° 0´
Trail 89mm (3.5 inches)
Wheelbase 60.9 inches
Seat Height 28.2 inches
Fuel Capacity 3.0 gallons
Mpg 68 MPG*
Curb Weight 422 Pounds (Includes all standard equipment, required fluids and full tank of fuel - ready to ride)
OTHER
Available Colors Pearl Red
Model Id NSS300
Note *Miles per gallon values are calculated estimates of fuel consumed during laboratory exhaust emissions tests specified by the EPA, not during on-road riding. Use for comparison purposes only. Your actual mileage will vary depending on how you ride and maintain your vehicle, weather, road conditions, tire pressure, cargo and accessories, rider and passenger weight, and other factors.
"Real World" MPG (based on average at Fuelly.com 5/24/2014) = 65.4 mpg
MSRP $5,599
